New Smaurai... HELP!!
  • 1691 Views
Offline BigRubbersOffRoad
  • 35
  • Sick Kick
« on: April 02, 2006, 04:56:46 PM »
I got an 88 samurai a few weeks ago. Since then I fixed all the rust and repainted the whole thing. Now comes the hard part, the motor!! I got it to start and run, but it seems like the choke is stuck. I can't get the rpm's down, it sounds like it's going to blow up. Also, when it's running it dumps oil out the back of the motor on the passenger side. Before I start taking it apart does anyone have any ideas what I should look for?
94 Sidekick- Trail Slayer SAS, 36'' Iroks, TT 4.24 crawler gears.
88 Samurai- 16v swap, 5.12 gears, 33'' Cooper STT
Offline kymike
  • 87
Re: New Smaurai... HELP!!
« Reply #1 on: April 02, 2006, 06:57:43 PM »
check the seal on the distributor for oil leak
Offline muskyslayr
  • 8
    • ibuilt Bumpers
« Reply #2 on: April 03, 2006, 04:59:26 AM »
Sounds like that blasted fuel pump...  There's a vent tube on the bottom, and once a pump starts going bad it spews oil out that tube.  As far as the high idle...How long do you let it run?  Sammies do have a high cold idle.  Mine sounds like it's going to blast off until it warms up. ;D
Sweet lookin Sammy by the way!! 8)
wwwibuiltbumpers.com
Offline Ian
  • 50
    • Island Rock Crawlers
« Reply #3 on: April 03, 2006, 10:01:56 AM »
The choke is likely stuck, it is pretty common.  I have heard of guys wiring them closed and I know some people have had success with adjusting them but they are finicky.  When mine gave me problems I ditched it for a Toyota carb.  As for the oil leak it is probably the distributor o ring.
