How to check, the Check engine codes
  • 1511 Views
Offline yamaharacerx
« on: April 03, 2006, 04:48:37 PM »
Hey so I have a 88' sami and like I was saying in another thread. The check engine light is on and I can't find the damn plug to check it. It says in the manual that there is a spot in the fuse block labeled Diagnosis, and you put a fuse in it and then the Check engine light will blink out a code and you match the blinking to the code given in the book, but I can't find anywhere on the fuse block labeled Diagnosis. In there another fuse block besides the one under the steering column.
Offline kymike
  • 87
Re: How to check, the Check engine codes
« Reply #1 on: April 03, 2006, 06:14:11 PM »
good luck ive had three all the same prob want to give me a phone number ill call you and tell you what i found
« Reply #2 on: April 03, 2006, 11:44:24 PM »
umm. sure my number is 509-323-4470. If you can call me try between 10am and 12am . or between 1pm and 2pm or between 3pm and 5pm. Sorry but I have class tomorrow at wierd times. I propably will be open after 7:30 tomorrow night to and i usually stay up pretty late..
Thanks for the help,
Micah
