will a toyota 22r fit in a sami
  • 1569 Views
Offline kymike
  • 87
« on: April 07, 2006, 07:31:29 PM »
does any one know or ever tried it is there adaptor plates 4 sale thanks 88 sami
Offline yotabob
  • 10
Re: will a toyota 22r fit in a sami
« Reply #1 on: April 08, 2006, 05:33:30 AM »
yes it can be done. i was thinking about doing it to my 86.
the best donor would be a toyota 4x4 pickup  with 22r, and  5speed.
use the entire running gear! the toyota trans and transfer case are not divorced like the samurai.  the 22r is a little longer than the 1.3 sammi. the radiator will likely have to be mounted forward just behind the grill.  instead of hacking up the floorpan on the samurai for the new shifter locations , cut some of the toyota floorpan out and weld it into the samurai.
i saw one of these done like this and  it was a clean deal. it just takes time and $$$$$$$$$$$$. :)
Offline lowrezolution
  • 292
  • "Get bent!"
« Reply #2 on: April 08, 2006, 06:10:05 AM »
With a little ingenuity, you can stuff anything between the frame rails.
I shoe horned a small block chevy and a Turbo 350 tranny in my '88 Mazda B2200.
Keep in mind things like room for exhaust, upgrading cooling system, and definity the wiring.
All can really add up $$$$. but the results are worth it.
2001 Tracker LWB
Boondox coil spacers and BDS springs 3.25" rear lift/3" front lift,3" body lift. 265/75/16 Durango Mud Terrains. (32")
