Engine fan questions
  • 11 Replies
  • 3269 Views
Offline 92jx
  • 15
« on: April 10, 2006, 09:38:38 PM »
hello all I bought a 92 jx 5 spd sidekick and the compressor for the a/c was takin off it b4 i bought it so i now have a ac condensor fan as well as a engine clutch fan
I was wondering if I removed the A/C (Radiator?) in front of the actual real radiator and removed the engine clutch fan  would the A/C fan be enough to cool the stock radiator.
i would like to use an electric fan instead of having my engine physically move the fan.
If you guys get what i mean it's a little confusing I know
Thanks alot guys
Re: Engine fan questions
« Reply #1 on: April 10, 2006, 09:57:24 PM »
I would think that the A/C fan is only good enough for a helper fan not a main fan.
My guess tho.
I don't know what  A/C is ;) ;D
Offline strvger
  • 95
  • Livin' on the edge... of the Great Northwoods !!
« Reply #2 on: April 11, 2006, 12:20:10 PM »
hi,
i'm thinking along the same lines but with this mod...  change the ac radiator to an oil cooler.  then remove the engine fan and replace it with an electric one.  both will be thermostat controlled and i would think it would help the engine lots.  any other ideas?  thanks.
'91 tracker, 1.6 8v 5-spd, 1.5 in susp lift,  DT header and 2 in exhaust, 235/75 AT's on 15x7 Turbines, 1st prototype: Ibuiltbumpers.com trackick front bumper!,  other mods coming soon!
Offline purpletracker
  • 115
« Reply #3 on: April 11, 2006, 01:03:50 PM »
My guess tho.
i don't have ac in mine  ..i used honda ac fan it seen to work good for me . hooked up to ignition "on " and regular switch so i can turn it off when crossing water ..
HotRod- A/C stand for automatic clutch,so you don't have to manualy turn on your fan clutch ;D
Offline 92jx
  • 15
« Reply #4 on: April 11, 2006, 02:37:07 PM »
lol no hot rod knew what he was talkin about he just he doesn't know what A/C is because he doesn't have it I think
Offline 92jx
  • 15
« Reply #5 on: April 11, 2006, 02:40:39 PM »
so I guess to be more precise would the helper electric fan be good enough on it's own since my a/c compressor has already been removed and it won't be creating any additional heat just so i can remove my mechanical fan.
and that would be one big a$$ oil cooler i wouldn't want it there in front if my rad if you were going to do that and just so you know you will be putting prolly close to 2 more bottles of oil in your system to use it lol.
thanks guys
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #6 on: April 11, 2006, 03:05:41 PM »
My fan clutch went out once so I removed the fan/clutch and unplugged the a/c comp. then turned on the a/c from inside and it worked fine for the rest of the trip. The pusher fan was enough to keep it cool even out here in so cal.
       Kevin
Offline biker
  • 730
  • It's a sickness I tell ya
« Reply #7 on: April 11, 2006, 06:04:49 PM »
I run my rig just like you want to do. Took out the engine mounted fan and installed an A/C fan in front of the rad on a t-stat switch. I also run an auto tranny and 34" tires which creates extra heat and I have no problem with heating up unless I have to pull a Heep out of the bush ;D
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline 92jx
  • 15
« Reply #8 on: April 12, 2006, 03:11:34 PM »
thanks alot guys does any body want a old fan lol or maybe a condensor lol
« Reply #9 on: April 12, 2006, 06:36:19 PM »
Yes, us poor folks can't afford that Fancy stuff. I'm just glad I got p/s ;D
  • 115
« Reply #10 on: April 12, 2006, 06:40:31 PM »
i would rip my A/C off if i have it  ..just to squeeze every lil once of hp out of my 80hp  motor.
i even tried to feed the squirrels   vitamins. ;D
Offline 92jx
  • 15
« Reply #11 on: April 12, 2006, 09:32:53 PM »
i wish i had power steering...
