awful mpg and steady high idle on 92 Tracker (1600 rpm)
  • 2816 Views
Offline Dan Olson
  • 9
« on: April 14, 2006, 10:15:34 AM »
Hello,
Just got a 92 Tracker.  It's stock with 70k miles.  Runs great except I'm getting about 12 mpg (all city) and it idles at 1600 rpm, warm or cold.
Any ideas?
Thanks
Dan
Offline Tracker_Camps96
  • 588
  • Who says a Tracker cant be fast and agile?
    • My lowrider/cardomain page
Re: awful mpg and steady high idle on 92 Tracker (1600 rpm)
« Reply #1 on: April 14, 2006, 11:12:01 AM »
Sounds like its running rich, but Im no mechanic.
96 Geo Tracker - K&N Filter, Calmini Header with 2" exhaust and performance muffler. American Racing Rims/Cooper Cobra GT tires. 2500 Watt Sound System w/Subs on tailgate.
07 Toyota Yaris Liftback- Stock
1980 Suzuki GS450L - 21K,stock, fixing up.  Kawasaki STX-12F - 125 hp  A pair of Adida
Jayzuki
« Reply #2 on: April 14, 2006, 12:54:07 PM »
Timing and fuel system. Ignition and censors. Clogged TB? Could be alot of things but check the basic's first.
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #3 on: April 14, 2006, 03:15:52 PM »
clogged exhaust system maybe a contributor to the problem.  Or restricitons on the air intake.  check for rats nests...
1993 4-door Sidekick
4.24:1 t-case
Offline Dan Olson
  • 9
« Reply #4 on: April 14, 2006, 05:18:34 PM »
OK thanks guys.  I checked the air filter, airbox, and intake boot and all are perfectly clean.
What is the next "basic" to check?
Thanks again...
Dan
Offline uglytrk
  • 51
    • trail krawlers 4x4
« Reply #5 on: April 14, 2006, 07:35:58 PM »
Did you try adujsting the idle speed?????
87 Samurai spoa/shackle reverse in front w/ toy rear springs5.43w/detroit quick lock yj 5 leaf pack rear 5.43 w/ detroit quick lock grs1 4:1 t-case w/ poly mount and rocky road mega arms warn m6000 optima red top 35/12.50 bfg mt`s on 15/8 aluminum wheels Hilift cb rock light cage in rear
Offline wezzlegod
  • 227
  • under construction crowler
« Reply #6 on: April 15, 2006, 04:07:34 PM »
what engine is it is it the tbi. if so i hade a high idle problem with mine the cold idle valve was stuck open. i hade to replace it.
