converting 2WD to 4WD Need Help !
  • 1532 Views
Offline borderc
« on: April 17, 2006, 11:46:56 AM »
Im looking for parts to convert a 1993 2WD SAM to a 4WD. Does anyone know where I might be able to find these parts? Anyone have any ideas on the best way to do this? If so you can email me at borderc|removethispart|@auburn.edu Thanks
« Last Edit: April 17, 2006, 11:54:10 AM by borderc »
Offline sutas
  • 20
Re: converting 2WD to 4WD Need Help !
« Reply #1 on: April 17, 2006, 12:28:41 PM »
borderc, not 100% sure about the sammy, but I have a trackick and there is a section in the (back) of my chiltons manual about what parts you need and the process of converting the 2wd to 4wd.  Also do a search around these forums and you should see something.  i'm actually looking to do the same with my tracker, when the space, time, money continuum allows for it!  ;)
I can tell you though, there is a spot that needs to be welded, but I cannot remember off the top of my head what that may be.
'94 Tracker 235/75 15 Goodyear MT/R's 1" wheel spacers.  more to come...
Offline borderc
« Reply #2 on: April 17, 2006, 01:53:27 PM »
Thanks for the info
Offline Shredder
  • 389
    • Me & My Rig
« Reply #3 on: April 18, 2006, 06:16:45 AM »
Actually a Sammy is pretty easy with a few parts from a salvage donar. Suzuki made the 2wd and 4wd ones almost the same.  Look under yours first to see what is missing. I'm sure you will at least need...
  • Front Axle (same ratio as your rear).
    Front Drive Shaft
    Transfer Case and Lever
Might need a bracket or crossmember too. ? ? Maybe a Sammy guy will chime in with more info. I have even been told that some had the T-case already there minus the shifter. Could get lucky.
