95 2door, 97 4door
  • 1305 Views
Offline kneescraper
95 2door, 97 4door
« on: April 18, 2006, 05:23:25 AM »
I have a 95 2door and just got a 97 4door that has a dead motor.  I got the 4 door because I need a front knuckle.  Should I change all of the suspension?  Will the 4 door stuff give me any lift, or better brakes?
What do you guys think of changing the complete wiring harness and computer to upgrade to the OBDII stuff?  I know that would be a lot of work, but would it be worth it?
Offline stock93tracker
  • 309
Re: 95 2door, 97 4door
« Reply #1 on: April 18, 2006, 07:30:39 AM »
4 door brakes will be a good improvement on a 2 door.  Suspension wont give you much lift but, if you want to do it, go ahead if you have the springs and what-not already   ;)
Cant help you with the OBDII question.  Im stuck with OBDI , havent had the pleasure of using the other..
93 Geo Tracker
-2" Lift
