rusted on everything
  • 9 Replies
  • 2713 Views
Offline weaver
  • 145
  • all i want to do is make my suzuki happy
« on: June 23, 2005, 08:34:24 AM »
yesterday i started to take off my bumpers, and was going to clean up all of that and the underneath in anticipation of my body lift,,    but it did not go as planned.       i cant even get the plastic bumper covers off let alone the rest..        im going to get some antiseize, but these things are a pain in the arse..   i cant wait until i have to take the body bolts off, im sure it will be a treat.
just thought id share my plight :P
98 2door clothtop stocker
2" BodyLift, 15x7's, 235's,
soon- filter, exhaust, etc. etc. etc. coil spacers, etc. etc. & more-----i think
Offline Cwkick
  • 888
Re: rusted on everything
« Reply #1 on: June 23, 2005, 08:37:49 AM »
Try some PTBlaster.  I have been told it is good stuff.
Cwkick
Offline Mythose
  • 361
« Reply #2 on: June 23, 2005, 08:44:04 AM »
PB blater is the best, cept for the stuff the ups mechanics use  they call it panther piss ??? but it works really well.
I use PB blaster on everything that is stuck.
Offline bandit86
  • 1641
  • elv8rguy
« Reply #3 on: June 23, 2005, 09:13:14 AM »
liquid wrench?
Offline jagular7
  • 1026
  • Jagular7
« Reply #4 on: June 24, 2005, 11:14:44 AM »
I've started to use the hot/cold method along with the PB blaster. You heat the nut (not bolt) with a small plumber's tank, then cool with water quickly. Do this 2-3 times, then add PB Blaster, wait 1-2 minutes, then try to remove. Make sure you remove any rust on the nut so that you won't strip it.....don't ask...
Lenexa, KS
Offline explosivo
  • 3157
« Reply #5 on: June 24, 2005, 11:28:08 AM »
Even when I used PB Blaster (damn good stuff, as everyone knows) I still ended up ripping off both the bumpers and covers, because the bolts were in there SOLID, and I ended stripping nearly every bolt/screw.
omghi2.us[/url]
Offline Capn_Crunch
  • 23
« Reply #6 on: June 25, 2005, 05:52:07 AM »
Welcome to the world of Suzuki.  If it ain't rusted on, it's stripped or stuck on with locktite.
Offline weaver
  • 145
« Reply #7 on: June 25, 2005, 08:08:36 AM »
hahaha yea, i tried removing some more bolts that are on my new wheels today, with the pb blaster too....   i finally got to the last two, and the damn bolt broke my drill bit,      the bumpers are still on too..    so i decided that it is miller time.
Offline jagular7
  • 1026
  • Jagular7
« Reply #8 on: June 26, 2005, 02:50:07 AM »
So did Miller do a better job than you?  ;D
Lenexa, KS
Offline weaver
  • 145
« Reply #9 on: June 26, 2005, 11:37:44 AM »
well to say the obvious ,  i felt much better once miller time came around..  i left the 2 bolts on for now, and on tuesday i plan to have access to air tools, and better working conditions all around..       i hope it goes smoothly -- its just a 2" lift, 15x7 wheels, and 29's or 30's,,,  i havent completely figured that one out.
