run rich need help
  • 2245 Views
Offline rednecksammy
run rich need help
« on: April 26, 2006, 02:02:27 AM »
need to no y 94 geo 16 tbi runs very rich and on accel backfire thro intake?
THE GO-UNIT!!
Offline FNG
  • 197
  • 91 TRACKER 6" LIFT ON 34S, SKID PLATES AND CAGE
Re: run rich need help
« Reply #1 on: April 26, 2006, 05:36:17 AM »
Timing?pcm? :-\
« Reply #2 on: April 26, 2006, 07:17:11 AM »
cam timing, bad O2, dirty air filter, tune up ..........
Offline derekj
  • 784
  • i'm the canadian guy eh?
« Reply #3 on: April 26, 2006, 08:18:06 AM »
cam timing - but also check the coolant temp sensor. if it is out of range the engine can run very rich.  how does the vehicle run? how fast can you get it going?
derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Offline Evolvocane
  • 90
  • the shop
« Reply #4 on: April 26, 2006, 02:13:32 PM »
derek
I had that probem,   youcan checkthe sensor by placing it in hot then cold and checking the resistance values with an ohm meter.  makesure its the right sensor though,  there are two.  One for the computer and one for the gauge.
DIY so ya can pay me to do it right later.
Offline Carnage
  • 2453
« Reply #5 on: April 26, 2006, 02:43:51 PM »
« Reply #6 on: April 27, 2006, 04:23:34 AM »
what do you mean cam timming? do you mean the belt jumped a tooth? changed the tpc and iac didnt check temp senser yet but had to turn up idle becuse it runs ruff at under 1500 rpm swoped map from parts truck didnt make diffrents will check temp senser and get back to you all
 thanks ;D
THE GO-UNIT!!
« Reply #7 on: April 27, 2006, 08:17:36 AM »
yes, a slipped tooth would
also change ignition timing
