Alternative Power Source
  • 2406 Views
Offline joe_and_jeep
  • Why have a Rev Limiter and not use it?
« on: April 26, 2006, 05:55:49 PM »
I been discussing this on Pirate with good review.  So I was wonder whatcha think?
http://www.pirate4x4.com/forum/showthread.php?t=467127
Basically I wanna run a motorcycle engine to a 4sp/t-case.  (1995 Tracker, Blown Motor)I would have all 5 M/C gears, 4 trans, 2 t-case.  I would have ridiculous low and super high.  It would be like running an engine with underdrive.  Also I would do a serious weight reduction.  If its not needed, it wont be in there.  Remove all of the interior except dash and front seats.  Maybe later remove most of the body and go buggy.  But I just want something to mess with on the trails.  Its not gonna be my main trail rig.
96 Tracker DD - 2in, 30s
95 Tracker Under the Knife - 4.3V6 - Rest Unknown
91 Jeep YJ Full Cage, Tri Link, D44/D44 35s
84 Jeep XJ Doubler HP44/9IN 35s
Offline bandit86
  • 1641
  • elv8rguy
Re: Alternative Power Source
« Reply #1 on: April 26, 2006, 06:39:24 PM »
a sprocket on the input shaft should be sufficient, give you some gear reduction too.  you will have to have the honda engine mounted sideways, which is front to back like the sammy engine used to be.
I was thinking about a similar setup from a virago 1000 engine, which is shaft drive, but it's air cooled, would overheat like no tomorrow
« Reply #2 on: April 26, 2006, 07:31:58 PM »
I have thought about this for a while and this is what I came up with.
1. Should be liqued cooled. Air cooled will work but you will need to run fans
to keep air moving over it. You may even need ductwork to get the airflow
through the cooling fins.
2. mount the engine sideways, mount a sprocket on the tranny input shaft
and put a double row chain to lock the two together (like a pump connector)
My big question is.....Will the stock bike clutch be able to handle the extra weight? ???
There are a few other small things I can think of that will need worked out but I shure would like to see someone try this. Let us know what you're doing!!!
Offline prairie_dog
  • 234
  • 85/413 tin top
« Reply #3 on: April 26, 2006, 10:02:43 PM »
What do you do with a zuki that runs to 12,000-13,000 RPM besides fly it (zaggy ;D)???????
Steve. :)
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #4 on: April 27, 2006, 04:05:09 AM »
I would love to see it if you get it done
« Last Edit: April 27, 2006, 07:18:37 AM by Quaddawg »
Offline gravity_storm
  • 108
  • The wino and I know
« Reply #5 on: April 27, 2006, 11:26:51 AM »
I've never seen how the Zukis handle it, but on all of the cars I've had a manual trans loose from, the engine end of the shaft is supported/kept in line by the pilot bearing in the crankshaft. Seems like you would need to fab up something on the front of the trans as well to take it's place. Very cool idea though. I like the way you think!
-Storm
1996 Sidekick, 1.5" homegrown body lift, 2" Digger suspension lift, home made snorkle, front skid
« Reply #6 on: April 27, 2006, 03:47:20 PM »
I have a 95 Tracker with no title and a blown motor so I been brainstorming  ;D
The clutch will hold it thru the power of gear reduction.  I want it to go flying thru the trails.  Stay on the stocker stuff.  I want to be able to jump it too.
I gotta get the yoke adapter and making and adapter to the trans will be simple, I will just steel the splined section out of the clutch.
There's also the chance that I might change my mind and put a 4.3 in it.  But I'm doing something different to it no matter what.
