Why is my 4 x 4 light blinking when i try to put put into 4 wheel drive
  • 1757 Views
Offline unclejr
i believe that it is not going into 4 wheel , what need s to be fixed on it to fix this problem
Offline Uncivilized
  • 1469
    • Car Domain
What are you driving?
Sounds like a GV or a Jimny. You probably have a leaky air/vacuum hose. First off, make sure that the pump is running, you should be able to hear it, if not check the fuse. If thats all OK check the lines for leaks.
« Last Edit: April 30, 2006, 06:34:21 AM by Rhinoman »
