Transmission question
  • 1881 Views
Offline clarkj
« on: May 03, 2006, 02:09:19 PM »
Hi, I am having trans. problems on my '96 Sidekick and want to know what years of Trackers/'Kicks have a 5spd that is interchangable with my '96.  It is a 4x4 with the 1.6 16V engine and is a 4 door.  Thanks for the help.
Re: Transmission question
« Reply #1 on: May 03, 2006, 02:55:55 PM »
89 thru 97 or 98 at least will work.
Some splines have been different
counts, so watch for compatability
Offline CodeBlue
  • 55
« Reply #2 on: May 05, 2006, 12:17:58 AM »
what type of problems you having? i have tried syncro mess and seems to help alot also lucis oil will work on some noises.
Offline clarkj
« Reply #3 on: May 05, 2006, 01:29:42 PM »
My trouble is that my transmission is whining pretty bad in every gear except 4th.  I am sure that new bearings would solve it, and I have the bearing and synchro kit, but I have never rebuilt one before and I figured I would see if I could find a cheap ride with a good trans and swap them and then try to rebuild mine and stick it in the one I bought if I got it back together right.  What are you talkin about with Synchro mess?  The people before me tried Lucas with no luck.  Thanks!
Offline CodeBlue
  • 55
« Reply #4 on: May 14, 2006, 03:01:33 PM »
syncro mesh (yellow bottle from most auto stores)  is just an oil additive. GM calls for it in some of their FWD cars. i tried it in other cars/trucks and it helps to quiet it. but if lucas oil is not helping then this will not either.
