91 Tracker brakes
  • 1355 Views
Offline snopro440r
  • 15
91 Tracker brakes
« on: May 05, 2006, 01:17:36 PM »
Hello might be a dumb question but do i have to take the hub assembly apart to get the brake rotor off? thanks
Offline snopro440r
  • 15
Re: 91 Tracker brakes
« Reply #1 on: May 05, 2006, 01:59:58 PM »
anyone?
« Reply #2 on: May 05, 2006, 02:22:49 PM »
You should just haave to remove the caliper. If it's sticky, there are threaded holes in the rotor to screw a bolt into that will pop it loose. Then it just slides over the wheel mounting studs.
