Another front housing bites the dust... time for an upgrade
  • 33 Replies
  • 8517 Views
Offline kozaz
  • 168
  • I love YaBB 1G - SP1!
Re: Another front housing bites the dust... time for an upgrade
« Reply #15 on: May 08, 2006, 07:36:45 AM »
I would like to put some information in one place about Housings and 3rds. I have the following info so far, but do not have all the info (see the ??s).
Can you guys help me make sure the info I do have is correct and help me fill in the spaces?
I'll Update this post as info comes available.
XL-7 2001+  4 doors
ENGINE
 Ã‚  2.7-Liter, V6, DOHC, 24-Valve
TRANSMISSION/with Related RING AND PINION RATIO
 Ã‚  Five-Speed Manual, Ring and Pinion 4.30
 Ã‚  Auto, Ring and Pinion 5.12
FRONT DIFFERENTIAL HOUSING INFO:
 Ã‚  All XL-7 have steel front Differential Housings, but the crossmember mount is different and does not directrly bolt to a GV, Vitara, Sidekick, or Tracker.    (crossmember needs mounting holes drilled in it)
 Ã‚   XL-7 Front Carrier uses airline to acitvate 4wd.
 Ã‚   Front Diff 26 Spline
 Ã‚   XL-7 CV shafts are longer than GV, Vitara, Sidekick, or Tracker CV Shafts.
 Ã‚   4 or 2 Pin Spider Gears ??
 REAR DIFFERENTIAL HOUSING INFO
 Ã‚   Rear Diff ?? Spline
Grand Vitara 1999+ 4 doors,
ENGINE
 Ã‚  2.5-Liter, V6,  24-Valve, 4-Cam, Engine
 Ã‚  Auto, Ring and Pinion 4.88
 Ã‚  99+ manual, 2004+ Auto, Grand Vitara have Steel Front Housings, Bolts directly to a Vitara, Sidekick, and Tracker (no modification required).
Vitara 1999+ 2 and 4-door,
ENGINE
 Ã‚ 1.6 Liter, 16-Valve, SOHC, Engine
 Ã‚ -or-
 Ã‚ 2.0 Liter, 16-valve, DOHC
 Ã‚   Five-Speed Manual, Ring and Pinion 4.88
 Ã‚  ALL housings are Aluminum
 Ã‚  26 Spline
 Ã‚   ?? Spline
Tracker  2 and 4 Door
ENGINE 1.3, 1.8 ??
 Ã‚  Five-Speed Manual, Ring and Pinion 5.12
 Ã‚  Five-Speed Manual, Ring and Pinion 5.38 (1989-91 8v Five-Speed 4 Door Only)
 Ã‚  Five-Speed Manual, Ring and Pinion 5.62 (1989 1.3 Five-Speed Only)
 Ã‚  Auto, Ring and Pinion  4.62
 Ã‚  Auto, Ring and Pinion  4.30 (Ca Model 16v 2 Door Only)
 Ã‚  ALL housings are Aluminum  ??
 Ã‚  96+ 26 Spline ??
 Ã‚  95- 22 Spline ??
 Ã‚  ?? Spline
Samurai  (I have not had time to research all the Samurai info.)
ENGINE 1.3 ??
 Ã‚  Five-Speed Manual, Ring and Pinion 3.73 ALL SWB??
 Ã‚  Five-Speed Manual, Ring and Pinion 3.90 ALL LWB pickups??
 Ã‚  ??+ 26 Spline
 Ã‚  ??- 22 Spline
 Ã‚  ?? Spline ??
« Last Edit: May 08, 2006, 07:38:59 AM by kozaz »
Offline the_maplebar
  • 466
« Reply #16 on: May 08, 2006, 07:38:02 AM »
After reading my first post again I think I may have confused you by stating that the Sami carrier is steel (implying that the sidekick isn't).  I'm not completely sure on that part, it was something I thought I picked up when seeing the Sami guys talk about using a sidekick 3rd.  They always say you should swap the R&P gears and not just bolt it up because the Sami stuff is stronger and steel.  Of course they may have just been talking about the 3rd member housing.
Here's a post Zig made a while ago to clear up his article a little bit.
http://www.zukiworld.com/forum/index.php?topic=8035.msg81849#msg81849
2002 4DR Tracker V6 ZR2.... 1.5"/2" coil spacers front/rear, BDS Strut Extensions, 235/75R15 Cooper STT... They ROCK!!!
http://www.zukiworld.com/forum/index.php?topic=35.msg111575#msg111575[/url]
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #17 on: May 09, 2006, 04:40:43 AM »
Yeah Maple, that is the sentence that made me think you were confused.. I can see now you aren't. ;D
I don't need the sammy carrier, as I am  not going to lock the front with  a sammy locker... I might get the trail tough locker and carrier.. I may not.
All I need is a steel 3rd housing for now.. Hawk says he has one.. but he won't price it via email, so I have to actually call and talk to someone... lol   will do that today.
  • 466
« Reply #18 on: May 09, 2006, 08:34:17 AM »
Just give him a call.  I have called  a couple of times, he didn't have what I was looking for but was very nice to talk to and picks up in 1-2 rings.
Offline hobgoblin
  • 224
« Reply #19 on: May 09, 2006, 11:50:26 AM »
Andy,
Here's the link to the fix I called you about.
http://www.izook.com/tech/tracker/pinion/pinion.htm
Hope this helps.....
Later Tom K.
Offline crikeymike
  • 713
  • Local to Western Washington?? Visit WAZUKS.com
    • http://www.wazuks.com
« Reply #20 on: May 09, 2006, 12:04:46 PM »
I heard that the newer "Chevy Trackers" like the funny looking body style ones from 98 or 99+ have steel fronts as well.  Can anyone confirm this?  It may be easier to find a junked one of those compared to a suzuki GV model.
1993 4-door Sidekick
3" hybrid Calmini/OME lift, 2" B/L, Rear air locker
Shrockworks bar & sliders, Full skid plates
4.24:1 t-case
 WAZUKS member - visit http://www.wazuks.com
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #21 on: May 09, 2006, 12:45:15 PM »
Jeezle Petes!!  Hawks want $255 for just the 3rd housing...
Too rich for my blood at this point in time.. that article said they got one for $165 from a dealer... didn't it??
OH WELL..
ACK, I guess I will take you up on that aluminum one for now..
PLEASE!!  lol...
« Last Edit: May 09, 2006, 01:06:00 PM by Quaddawg »
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #22 on: May 09, 2006, 12:55:37 PM »
Crap.. no wreckers around here even HAVE  a GV..
I am going to have to weld this one up and add some beef... or something..
I will swap ACK's in for now.. but it'll break again..
What started out as a love affair, is slowly sending me back to Jeeps.. these little trucks just aren't made for this sort of abuse.....
I don't care for the ride of a SAS on a tracker........  CRAP..
Maybe I will just sell this thing and move to another hobby..
dejected.... broke.. and tired of breaking stuff so easily..
  • 466
« Reply #23 on: May 09, 2006, 01:31:06 PM »
How easily you sway to the darkside...  :P   Here's the link to the reinforced 3rd member.
http://www.cardomain.com/ride/240265/4
Might be a good plan if you have a buddy that can weld aluminun.
It seems that the steel diff/3rd were cheaper and easier to find a few years ago before EVERYONE knew about them and wanted to upgrade.
  • 466
« Reply #24 on: May 09, 2006, 01:37:56 PM »
I don't think so.  Mine doesn't and Chevy did not offer a MT with the V6 (which is where you find them on the Suzukis).
Offline brlj
  • 512
  • 6" Lift w/ 33x12.50 TSL Radials, Exoskeleton
    • Bills 93 Tracker
« Reply #25 on: May 09, 2006, 02:04:12 PM »
dawg, just get a sammy rear 3rd and use it up front. Youll have to weld a block on it for the pinion mount. Theres a tech write up on it by Mike. The thing I really like is its got 4 spider gears instead of just 2. I busted my stock spiders at the Melt last year. Ive got a extra housing but no carrier, if you can find a cheap or freebee carrier youll be in business..
Bill
  • 466
« Reply #26 on: May 09, 2006, 02:52:41 PM »
Are you talking about this
http://www.zukiworld.com/month_020103/feature_frontendupgradeswithhagen.htm
It says he's using a Sami carrier with the GV 3rd member housing.
However that would probably work since you can bolt a Sidekick front to a Sami.  Has anyone done that?
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #27 on: May 09, 2006, 03:30:38 PM »
'03+ Grand Vitaras, regardless of manual tranny or auto, have steel front housings.  I checked and ours has steel despite it's auto trans.
Now let me say that we have a late year '03 and it has more in common with '04 models than earlier '03 GV's....soooo some '03 GV's might have aluminum front housings...I dunno for sure. :P
Jeeps break too, remember the D30 front axle and the D35 rear axle...then there's some of their craptastic transmissions...
« Last Edit: May 09, 2006, 03:40:56 PM by AJMBLAZER »
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #28 on: May 09, 2006, 03:37:59 PM »
Yeah, maybe a sami carrier would be better in the long run...
LOL...
I am just venting.. I love this little truck...  but as soon as I get some cash together, I am seriously thinking ANVIL!!   or at LEAST steel for both housings.. then I wonder what breaks.. prolly axles... lol...
Offline brlj
  • 512
    • Bills 93 Tracker
« Reply #29 on: May 13, 2006, 03:46:20 PM »
The sammy rear 3rd will bolt into the aluminum housing. This is the setup  I run with a Lockrite.
Bill
