try to lift a 4doors sidekick 95 but...
  • 1887 Views
Offline legrandgazou
  • 6
« on: May 07, 2006, 09:23:58 AM »
 Hi, on my sidekick there`s  11 places to put the spacers, in the front and the back it`s no problemo but on the side i can`t reach the bolt.The two nearby the wheel are sealed and the one under the seat well i can`t see it...
   Shoulde i drill hole inside or outside(interior fender)or what???he;p me Thanks
Offline Uncivilized
  • 1469
    • Car Domain
Re: try to lift a 4doors sidekick 95 but...
« Reply #1 on: May 07, 2006, 12:05:17 PM »
There are only 8 bolted mounts, the other 4 are just spacers to support the weight and keep the floor from sinking. Most people just glue the lift blocks on top of thoes locations temporarily till your done, then you can tack weld the block to the frame if you want.
  • 6
« Reply #2 on: May 07, 2006, 03:23:17 PM »
   Ok then wich ones are the mounted bolts.I see 3 in the front, 2 in the back and 3 on each side between the 2 wheels.Do you mean that if I unscrew the 3 in the front and the two in the back and begin to lift the truck it will come apart? Thanks for the help
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #3 on: May 07, 2006, 09:24:51 PM »
The body mounts are located:
Two in the front = One on each side under the headlights (behind the grill/bumper)
Two under the front floorboards = One on each side (look where the arm comes out from the frame on each side)
Two under the rear seat = One on each side (again, look at where the arm comes out from the frame on each side)
Two in the back = One on each side behind the back bumper/below the back door
The spacers are located:
One on each side between the front floorboard and rear seat body mounts - this spacer is between the frame and body.
One on each side at the top of the frame above the rear wheels - next to the gas tank. Again, this spacer is between the frame and body.
This all equals = 12 spacers/mounts.
If you haven't already, see:
http://www.granitepath.com/~irving/suzuki/budgetbodylift/index.htm
There's a couple broken links there (I need to go through my site) but the photos might help.
These pics might help too:
http://www.granitepath.com/~kd7hcg/pictures/bodylift/index.html
http://www.granitepath.com/~kd7hcg/pictures/bodylift2/bodylift2.htm
http://www.granitepath.com/~kd7hcg/pictures/rearbumper/index.htm
« Last Edit: May 07, 2006, 09:27:17 PM by hcgalvin »
Heather Galvin
