wheel differences
  • 9 Replies
  • 5621 Views
Offline jeffry
  • 87
wheel differences
« on: May 07, 2006, 09:47:28 PM »
Are the stock steel wheels from a Grand Vitara and an XL-7 the same? Getting differing opinions from local junkyards and want to make sure I get a complete set that are the same as I cobble together five new rims for a second set of tires.
Thanks,
Jeff
Offline blacknight
  • 987
    • Gonzookin
Re: wheel differences
« Reply #1 on: May 08, 2006, 05:43:16 AM »
The Grand Vitara wheel and the XL-7 (16x7)  are the same the Vitara(16x6.5 i think) and tracker (15x6.5 or 7?) wheels are different
George
Offline the_maplebar
  • 466
« Reply #2 on: May 08, 2006, 06:57:25 AM »
The Tracker's steel wheels are 15x5.5 the upgraded alloy wheels are 15x6, but those probably won't fit on a GV or XL7 except possibly if you use wheel spacers.
Offline jeffry
  • 87
« Reply #3 on: May 08, 2006, 08:37:26 AM »
George
Yes, the Vitara are 16x6.5, which is what my current wheels are. I've got a set of Wrangler MT/Rs in 245/75/16 to put on and need another set of wheels, so wanted to go with the wider wheels of the Grands, but some of the local parts people were giving me a hard time - even though I was pretty sure the XL7 and Grand were the same, just thought I'd check. Scary how stupid some of the people selling parts are _ one guy said - "they are wider, it will mess up your vehicle, especially if it is 4wd." Plus, they want more for junkers than I can get new ones for on ebay. Crazy.
Thanks,
Jeff
Offline Maroon Monsoon
  • 876
« Reply #4 on: May 08, 2006, 06:00:49 PM »
I am almost certain that GV and XL-7 rims are identical. 16X7 and stuff.... Yea, I see many XL-7's that have the exact same rims that I do on my GV.
if it's possible I'd double check before you buy just in case.. can't be too sure you know
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #5 on: May 08, 2006, 06:40:32 PM »
  • 466
« Reply #6 on: May 09, 2006, 08:46:49 AM »
I would second that.  At one point I saw an OEM replica wheels site, can't find it now, but it had photos of the various styles of wheels associated with different trim packages.  I am sure they are all 16x7, but some may "look" slightly different depending on year, trim etc.
Offline jeffry
  • 87
« Reply #7 on: August 30, 2006, 10:56:10 AM »
just an update - bought a set of GV/XL-7 rims (16x7 vs 16.6.5 for the stock Vitara) and no rubbing except a tiny bit at full lock with the 245/75/16s. With the stock rims my 235/70/16s rubbed more. Crazy.
Thanks,
Jeff
Offline ZeusZuki
  • 411
« Reply #8 on: December 08, 2006, 08:44:57 PM »
A bit late but here goes:
GV / XL7 wheels are interchangeable - 16 x 7
1600 GV and widebody not the same - either 15 x 5.5 or 15 x 6.5 or 16 x 6.5 BUT different off set.
The GV / XL7 rims stick out towards the guards more - the caliper / disc combo is not the same. The caliper is a larger design and thus the reason for the off set. GV / XL7's MUST run 16" rims - 15" rims WILL NOT WORK  ::). I know this because I just did a 4" lift on my V6 GV and thought I would run the 235/85 x 16 rubber off of my Widebody BUT the wheels would not fit so I have to swap the tyres to my GV rims. On the positive side though - the rims will then fit both vehicles  ;D.
ZeusZuki  8)
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #9 on: December 14, 2006, 05:51:53 PM »
Just to add a little more info to what ZeusZuki said. The GV/XL-7 16"x7" rims are a 5P offset and the 16"x6.5" rims as fitted to our 2.0 V6 Vitara/Escudo(1.8 Sidekick Sport) has a 25P offset. The brake discs are the same diameter and thickness but Suzuki shifted the disc position further outboard by 17mm.
