Newbie here w/? 4 Heather and Nate
  • 20 Replies
  • 5692 Views
Offline hcgalvin
  • 1695
    • Granite Path
Re: Newbie here w/? 4 Heather and Nate
« Reply #15 on: June 23, 2005, 05:00:49 PM »
sorry the other question for the other people in the know is will the toy axles even take that much torque ....in total offroad magazine there was a nissan GQ wich nissan's own back axle is almost as strong as a ford 9" ...this truck was using a 6.5 duramax and b4 they did the upgrades to the engine they had to go to dand 60"s i think they said
The FJ80 axle is pretty much considered a 9", in all technicality.
Plus, it's not just the engine that can put out torque.. it's also the gears. ;)
We were putting almost 900 ft lb of torque into the stock suzuki axle with both the transfercases in low gear, (one with 4.24) and the factory 5.12's. :O
Yeah I know.. 95 hp, and 900 ft lb. :P (we calculated the torque with all the numbers in the truck)
I'm pretty sure the FJ80 axles can handle it.
« Last Edit: June 23, 2005, 05:01:43 PM by hcgalvin »
Heather Galvin
Offline bus_driver
  • 479
  • the voices tell me different things
« Reply #16 on: June 24, 2005, 08:25:33 PM »
i love mechanical power .....forgot what I was wathing but the torque of this buggy after all said and done was around 2600lbs of torque......crazy stuff....
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline bus_driver
  • 479
« Reply #17 on: June 24, 2005, 08:26:05 PM »
oops mean 26000lbs
92 2dr soft top
235/75/15
2 inch lift
custom mud
« Reply #18 on: June 25, 2005, 04:43:06 PM »
Remember that torque is the motivating force,
and even tho there might be a 26,000 ft lb output
with the gearing, it would be very difficult to get
that much power to the axles before the truck
starts to move, unless you are totaly stuck in solid
packed sand or trying to pull somebody out, you
would more than likley never reach that torque
output and snap axles, could happen, but I think
you would have to be trying really hard to do it
Offline bus_driver
  • 479
« Reply #19 on: June 25, 2005, 08:34:09 PM »
isn't trying too brake things half the fun? don't know the other half but will tell you when I am there
92 2dr soft top
235/75/15
2 inch lift
custom mud
Offline mesjr2004
  • 422
« Reply #20 on: June 26, 2005, 03:00:53 AM »
i know a guy with a sammy that has the 6:1 or 8:1 tcase ,not shur wich.but hes running dana 44s an lockers and has broken ring and pinions and axel shafts and u joints ,i couldnt believe it ,never thought a sammy could break 44s that easily ,hes gone through several axel parts .but hes really hard on it and binds it up every chance he gets.
