Newbie here w/? 4 Heather and Nate
  • 20 Replies
  • 5649 Views
Offline Diesel Duke
  • 6
    • Jehovah's Witness
« on: June 20, 2005, 06:51:08 PM »
I've been lurking here in the past six months and have gotten to know a lot about the posters here... And I have one small question for Heather and Nate, I'm doing a SAS on a 2005 Tracker and would like to know that if I use FJ-80 Axles front and rear do they come with the electric lockers already or is that something I have to purchase separately? And which leafs springs did you use? I'm debating on them or Dodge Durango Springs backed with Nitro filled Shocks. I already have redone the engine bay with a GM 6.2L  Diesel with a Gale Banks Blower Just the engine alone is putting out
+124 hp and +303 lb-ft . The engine bay is crammed tight and the firewall has been pushed back 4 inches yet I've managed to retain the stock appearance. Now I need to turn my attention to the suspension if I want to keep the 4 wheeldrive, my transfer case is no longer stock and I now have a Dana 300.
I'm a Jehovah's Witness a proud of it...
Offline explosivo
  • 3157
Re: Newbie here w/? 4 Heather and Nate
« Reply #1 on: June 20, 2005, 11:00:10 PM »
I DEMAND that you post pics before anyone help you out... that sounds like a kickass rig, and I wanna see it! ;D
I believe they are using YJ springs... might be too soft for the additional weight of the diesel, though :-/
omghi2.us[/url]
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #2 on: June 20, 2005, 11:04:39 PM »
I second this!! Pictures Please!
-The YJ springs might work if you add a leaf or two, but then again, that sounds like a heavy engine....
Offline TomKat
  • 211
« Reply #3 on: June 20, 2005, 11:30:18 PM »
   8) 8) 8)
88.5 Sammy,YJ's,33's,Yota axles,4.9-1 'case,dents and rust...
Offline real_red_wagon
  • 226
  • Make It Hert!!!
« Reply #4 on: June 21, 2005, 03:44:07 AM »
Wait a minute they didn't make '05 trackers >:( Whats going on here ??? this sounds a little far fetched :-/(no offense) ;)
At Lakeview Motorsports, were wasting your time already!
Offline chet
  • 556
  • Zuki time!
« Reply #5 on: June 21, 2005, 04:06:54 AM »
fj-80 axles are offset front and rear and to work with a Dana 300 your rear driveshaft will be on an angle.
Yes you can get the fj80 diffs with factory lockers, they are more common without the lockers though.
whatever leafs Heather and Nate used willnot work for you as your engine is WAY heavier than theirs and will require different springs to compensate!!!
oh and PICS!!! ;D
Offline SnoFalls
  • 1358
« Reply #6 on: June 21, 2005, 08:12:24 AM »
SAS on a late model trac/kick  :o ... CANT WAIT FOR PICS !!!!
Offline Diesel Duke
  • 6
    • Jehovah's Witness
« Reply #7 on: June 21, 2005, 12:22:14 PM »
Let me clarify this it's a 2003 ZR2 4 Door purchased new in Jan. 2005 new from the dealership with Zero miles. Not trying to pull the 'wool' over anybody's eye's here. I also don't care what you think, it's not yours anyway and I have nothing to prove, other than my lack of knowledge for the FJ-80 axles and which spring rate to use. (no offense)
As for photograph's they're under wrap's till the trucks' day-view with Kelly Conlin and PRIMEDIA publications so you will have to wait for their release until till then.
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
« Reply #8 on: June 21, 2005, 01:06:04 PM »
Congrats on having the guts and the cash to do something like this but I hope you did something to strengthen the frame cause that big diesel is gonna twist your frame into a pretzel.
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #9 on: June 21, 2005, 04:01:20 PM »
Sorry I didn't respond sooner, I've had to start working nights, and my schedule is all messed up.
So to answer your questions..
Certain FJ80 axles will come with the electric lockers STOCK. You'll have better luck with the lockers in axles out of 94-97 model year vehicles. Those are also front high pinion, and full floating front and rear. They sometimes consider those years the F -Z- J80.
The FJ80 axles front and rear are right hand (passenger side) offset.
Here's a site with a listing of used parts for an FJ80, axles included.
http://www.cruiserparts.net/parts/fj80.htm
Look around at your local junkyards too. That's where we found ours.
Bobby Long also makes birfields for the FJ80s.
http://www.longfieldsuperaxles.com/
As for the leaf springs, we run Sky Jacker "Rock Ready" Double Mil Wrap lift springs. They are strong springs, and may work for your setup. We run 2.5" lift in the front and 4" lift in the rear. They work well, and so far have settled perfect.
http://www.quadratec.com/cgi-bin/sgdynamo.exe?HTNAME=jeep/skyjacker/lifts.html&checked=Y
Our buddy with the Bowtie tracker (283 v8 203 tranny) uses the Skyjacker springs as well. He went 4" lift all the way around.
I bet that the weight the YJ's carry with the 4.0s in the front would most likely equal out similar to what you have, when decked out as well.
Stock Chevrolet Tracker Curb Weight - 2700-3000lbs
Stock Wrangler YJ - (from what i can find) is 3050-3400lbs.
Add bigger tires, bolt ons, etc... (I've googled and seen some jeeps weighing in at 6000 lbs)
Anyway.. I know MY truck weighs somewhere around 4-4500lbs curb weight. (amazingly) The springs have handled just fine.. and I haven't needed a traction bar. You may, with your engine, though.
You will also need to obtain or make a high steer arm for the FJ80 axle. We sent off our knuckle to OTT Industries who modified it, and made an arm for us. The price wasn't bad, and the arm is WAY strong.
You have to be patient with OTT, though. Don't be in a hurry. I think they're a three man shop, and get things done as they can, one after another. They do good work though.
Hope this helps. Let me know if I can answer more questions for you.
« Last Edit: June 21, 2005, 04:03:32 PM by hcgalvin »
Heather Galvin
  • 6599
  • 68
« Reply #10 on: June 22, 2005, 01:41:07 AM »
Easy there Diesel Duke, Since this was your second post I thought I'd help get you used to the way we talk with each other there. Real_Red_Wagon asserted a question with an abundant amount of smilies to let you know that he has a bit of skeptisizm in what your saying but is not trying to ruffle your feathers.
Your reply seemed to indicate your feathers we ruffled.
Please take a moment to read this thread http://www.zukiworld.com/cgi/yabb/YaBB.pl?board=suzuki_talk;action=display;num=1119382361
Thank you, Eric
Offline barcus
  • 97
  • fun
« Reply #11 on: June 23, 2005, 04:36:57 AM »
hi hcgalvin, the fj80 axles, what gear ratio are you using? thanks
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #12 on: June 23, 2005, 05:49:33 AM »
They're 4.10..
I can get 4.88 or 5.29 if I need to.
I'm ok going down the road, a little clutch slippage at lights, but I can do 65-70 on the freeway. This is with two transfercases.
I'm planning on though, getting gears for the sammy case which will lower my high range and compensate, so I don't have to tear apart the diffs.
Heather Galvin
Offline bus_driver
  • 479
  • the voices tell me different things
« Reply #13 on: June 23, 2005, 04:12:20 PM »
hey was just reading sounds really cool the only questions I had and did not see answered(sorry if it was) did you strengthen chassis? the other question was about the engine.....you might wanna check the numbers again since the 6.2 in an 87 burb was putting out 150 hp and jus over 300 lb ft of torque have you dynoed it yet? and does it ride on the front wheels only  ;D ;D
the engines is about 800 lbs if my memory is correct..
love too see the engine bay only !
« Last Edit: June 23, 2005, 04:12:49 PM by bus_driver »
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline bus_driver
  • 479
« Reply #14 on: June 23, 2005, 04:15:38 PM »
sorry the other question for the other people in the know is will the toy axles even take that much torque ....in total offroad magazine there was a nissan GQ wich nissan's own back axle is almost as strong as a ford 9" ...this truck was using a 6.5 duramax and b4 they did the upgrades to the engine they had to go to dand 60"s i think they said
« Last Edit: June 23, 2005, 04:16:02 PM by bus_driver »
92 2dr soft top
235/75/15
2 inch lift
custom mud
