After Market cross member for Trackers/Vitaras/Kicks?
  • 4783 Views
Offline ice_man5210
  • 10
« on: May 16, 2006, 09:05:46 PM »
Is this an aftermarket cross-member for Vitaras?  What do you guys think of this?
rough translation of the text:
This product is manufactured in plate from steel and when what guarantees a high resistance to the corrosion and at the time was galvanized white.
This Crossbeam is super reinforced and put an end to the problem of trines of the original crossbeam!!!
came from this website:  http://www.rc4x4.com.br/
Offline joe_and_jeep
  • Why have a Rev Limiter and not use it?
Re: After Market cross member for Trackers/Vitaras/Kicks?
« Reply #1 on: May 16, 2006, 09:45:54 PM »
I bent my crossmember the first time out.  A better crossmember would be awesome.  But I am cheap and enjoy fabbing my own.
I couldn't tell from the pics on how durable it really is.
96 Tracker DD - 2in, 30s
95 Tracker Under the Knife - 4.3V6 - Rest Unknown
91 Jeep YJ Full Cage, Tri Link, D44/D44 35s
84 Jeep XJ Doubler HP44/9IN 35s
Offline Maroon Monsoon
  • 876
« Reply #2 on: May 16, 2006, 10:35:47 PM »
I would guess it's for a 1st gen track/kick because they've been around longer and more stuff has been developed for them; however it looks like it would fit a 2nd gen track/vit as well. not sure though. THe only difference I've noticed in the frames of both is the front part.. middle and back of the frame seem the same to me but I haven't done much comparing of anything but the front ends of those frames
I bent my front cross member.. too bad I can't bolt a new one on... it's integrated into the frame... oh well, didn't bother it other than looks
Offline barcus
  • 97
  • fun
« Reply #3 on: May 17, 2006, 03:43:49 AM »
have rod fabricate one for you.  ;D
« Reply #4 on: May 17, 2006, 04:47:44 AM »
I think it is for the first generation Track/Kicks. I looked into reinforcing or replacing my crossmember some time ago. I think you would just end up with the mounting brackets on the frame getting very bent. A decent skid plate saves the crossmember, it allows the truck to slide over stuff.
Offline the_maplebar
  • 466
« Reply #5 on: May 17, 2006, 06:28:47 AM »
I agree it's for the Track/Kick (AKA Vitara in foreign countries).  E-mail them, Rodrigo works there and speaks english although it may take a few days for him to respond if he is on travel or something.
  • 876
« Reply #6 on: May 17, 2006, 02:12:07 PM »
I agree as well, skid plate instead of new cross memeber seems like the way to go
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #7 on: May 17, 2006, 04:57:23 PM »
So uhm...which crossmember does this replace? ???
« Reply #8 on: May 18, 2006, 05:16:10 AM »
Back of gearbox/tcase. The stock one is very vulnerable
