Getting ready to build new Track/Kick
  • 1743 Views
Offline joe_and_jeep
  • Why have a Rev Limiter and not use it?
« on: May 20, 2006, 10:14:27 PM »
I'm starting to get stuff together to build my 95 Tracker.  Here is what I got.
1995 Tracker Tin-Top 16 Valve - Auto - Blown Motor
4.3 Vortech Chevy
TH350
T-Case Undecided
2.5 Rockwells
46in Michelins
I have my 96 Tracker for my street legal wheeler, and I have my 91YJ as my moderate wheeler.  I was thinking about going all the way with the Rockwells.
Here be what I thinking, somewhere around 109in wheelbase.  The final plan is to run 46in Michelins.  But I am stuck with 42s till I get some more money.  The 46's are cheap, the beadlocks aint.  Suspension in the rear will be a tri-link.  Simple to build and I have built them with success and like the results.  For the front I was thinking about going really simple and doing a wristed setup.  Something like 40" arms.  I found a cheap supplier of 2" .250 wall square tubing and he also sells this other solid stock that fits inside the square.  So basically you get a solid arm.   Coils will be probably stock TJ.  Dont got the cash for fancy coil-overs.  Steering will be full hydraulic.
I think the frame will be ok with a good rollcage in it.  Rad will have to get creative, but that aint all that bad.  Specially compared to my YJ.
So I have everything listed, still need some other stuff to get started.  But I think this will be a fun project, I have to retire my XJ so this will be its replacement.
Thoughts, comments, concerns, ideas?
96 Tracker DD - 2in, 30s
95 Tracker Under the Knife - 4.3V6 - Rest Unknown
91 Jeep YJ Full Cage, Tri Link, D44/D44 35s
84 Jeep XJ Doubler HP44/9IN 35s
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
Re: Getting ready to build new Track/Kick
« Reply #1 on: May 20, 2006, 10:32:03 PM »
I would attatch the cage to the frame to help keep it rigid. I would also try to plate the frame where the control arms attatch. The frames are pretty thin.
Mike
« Reply #2 on: May 20, 2006, 10:40:54 PM »
Definately tying the cage to the frame.  I saw some posts on Pirate about the frame being thin on the Sami's.  Didn't know about the Track/Kicks.
