Calmini Cage
  • 32 Replies
  • 6493 Views
Offline magiccat
  • 98
  • 94 Sidekick 2.5 spacer lift 30x9.5 mt's
Calmini Cage
« on: May 21, 2006, 08:41:56 AM »
Has  anybody rolled with the camamini cage installed?
Did it hold up?
How does the cage get tied in?
Does it tie in to the frame?
Is there welding?-Or just bolting?
Dimensions?
Is really all that much cheaper and safer to make your own?
Thanks
« Last Edit: May 21, 2006, 08:53:11 AM by magiccat »
Offline magiccat
  • 98
Re: Calmini Cage
« Reply #1 on: May 21, 2006, 08:57:57 PM »
any info on the calmini cage? ???
Jayzuki
Re: Calmini Cage
« Reply #2 on: May 21, 2006, 09:24:43 PM »
I am sure it would get damaged in the event of a roll-over and I think it required welding and drilling for the install?
Will look way better, for sure.
Offline Yoak
  • 577
Re: Calmini Cage
« Reply #3 on: May 21, 2006, 10:17:16 PM »
Im almost 100% sure there is welding required to install it, I remember that from a magazine they sold me
Re: Calmini Cage
« Reply #4 on: May 21, 2006, 10:19:28 PM »
For a SideKick?
Heres what i know.
1- Is really all that much cheaper and safer to make your own?  buying the cage is cheaper than having a shop built one from scratch.
2- Is there welding?-Or just bolting?
 Yes, there is welding, grinding, and bolting.
3- Does it tie in to the frame?
 No, it doesn't tie into the frame (be better if ya did tho)
4- Has  anybody rolled with the camamini cage installed?Did it hold up?
haven't heard anybody rolling one with a Calmini cage in a Kick, yet. I know I've come close, more times than I would like.
5- About so big by so big
Re: Calmini Cage
« Reply #5 on: May 22, 2006, 04:59:36 AM »
If you're tall you will need some padding on the cage too, to protect your head.
Offline FNG
  • 197
  • 91 TRACKER 6" LIFT ON 34S, SKID PLATES AND CAGE
Re: Calmini Cage
« Reply #6 on: May 22, 2006, 05:22:38 AM »
I do not know the demensions.It bolts into the cross members,welding,fitting and notching are required. ;D
Offline Uncivilized
  • 1469
    • Car Domain
Re: Calmini Cage
« Reply #7 on: May 22, 2006, 07:16:04 AM »
any volunteers to see how it holds up?  ;)
just kidding. I'm sure it's designed well, and will hold up much better than nothing. If Calmini was selling a roll cage that wasn't functional and only for "looks" they would most definatly have to specify that about 20 times on their website. Roll cages are good insurance for your life.
Offline magiccat
  • 98
Re: Calmini Cage
« Reply #8 on: May 22, 2006, 09:37:01 AM »
It sure does look good though- structurally
I am about 6'1 so I probally would need padding
Is it adviseable to make your own- if you have never made one before?
It is something you wouldn't ot cut shortcuts on
I have a 15 month old girl - I woukd like to give her and my familly some protection!
Myself included Does it protect passengers in the rear?
With a 12 ton pipe bender can you bend tubing the same dimesion as calmini used?
"any volunteers" - that was a good one! ;D
It would be interesting to see how it holds up
Thanks for the help
« Last Edit: May 22, 2006, 09:39:13 AM by magiccat »
Offline FNG
  • 197
Re: Calmini Cage
« Reply #9 on: May 22, 2006, 11:25:30 AM »
This cage does nmot offer rear protection but i plan on adding on to it.I plan on removing the down tubes ehen i add on.
Re: Calmini Cage
« Reply #10 on: May 22, 2006, 09:18:56 PM »
But, to make it stronger you would need a cross brace like so.
This would make the cage stronger and not collapse would rolled over.
Re: Calmini Cage
« Reply #11 on: May 23, 2006, 01:54:19 PM »
If your going to bend your own cage up, make sure you use a tube bender instead of a pipe bender.
A pipe bender will weaken the bends where you bend it (There has to be a better way of saying that...).
Offline magiccat
  • 98
Re: Calmini Cage
« Reply #12 on: May 23, 2006, 03:38:47 PM »
Thanks for the tips
How much are tube benders?
I found a cheapy 12 ton pipe bender at harbor freight for around 80 dollars I belive. glad I didn't get it.
Will that additional brace interfere with the rear passengers at all?
thanks again
Offline JayN
  • 220
Re: Calmini Cage
« Reply #13 on: May 23, 2006, 07:23:04 PM »
the cal one looks o.k, i just built a rear cage for my kick, need to add a front exo to it still.
96 sport, safari rack, lift
1970 gmc truck
1950 dodge truck
1974 corolla
Offline cwilkinson
  • 30
Re: Calmini Cage
« Reply #14 on: May 23, 2006, 07:27:54 PM »
You can get your dimensions and stuff and lay out your cage and probably get the material bent at a machine shop for a reasonable price I'm going to build an external cage with 2 inch thin wall carbon like schedule 10 or 20.. which should be stout enough, or you could just weld it out with regular old pipe fittings use small bore piping run straight down through the floor and buttweld directly to frame or build a support with a peice of pipe coming up and go all the way to the roof and use long radius 90's and come across the top with a peice of pipe would be stout as hell still
