MIKE H. rear end ?
  • 13 Replies
  • 3671 Views
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
MIKE H. rear end ?
« on: February 09, 2005, 06:35:00 AM »
hey mike i was looking at your website and see u r running a 9" rear. i was wondering if you had to cut it down and if not what did it come out of and where did u get ur gears. i have a 44 front and a 9" rear out of a bronco and we are going to shoten them this weekend. if u got ur 9" out of a vehicle and it fit it would save me alot of time and money if i don't have cut the ones i got and order axleshafts. i am going to run a kicker3 case to a sammi to eliminate the slip yokes and tom woods high angel drive shafts. i have it all drawn on auto-cad so everything is measured and clearanced just need to bring all to the real world. i am planning on running 4.10 axle gears with a 4:1 lowrange in the sammi case. i figure that should be about right for 37" to 38" tires. i forgot to say that i will be making my wheel base 8.6" longer for a little more stability.
« Last Edit: February 09, 2005, 06:45:09 AM by tracker8wr »
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline Cwkick
  • 888
Re: MIKE H. rear end ?
« Reply #1 on: February 09, 2005, 06:39:14 AM »
I can just hear the jokes!   ;D
Cwkick
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #2 on: February 09, 2005, 07:23:58 AM »
No kidding, espcially starting with "I was looking at your..."
:o :o
:o
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
« Reply #3 on: February 09, 2005, 07:33:58 AM »
My 9" is Stock CJ width and is Narrower than the Factory Kick rear axle. I had to use spacers to get it as wide as the Kick axle. It is a Currie Unit that came out of a UROC buggy. I have not been looking closely at Mikes Rear End ::) so he will have to speak for himself on how WIDE it is :P ;D
Offline 1bigtracker
  • 3409
Offline 1bigtracker
  • 3409
« Reply #5 on: February 09, 2005, 07:53:13 AM »
one of my favs
« Reply #6 on: February 09, 2005, 07:57:23 AM »
"After doing a little research I found that a 73 Ford Bronco rear axle is only 3 inches wider than a Tracker"
Quote from article ;D
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #7 on: February 09, 2005, 08:31:45 AM »
What he said ;D
Offline tracker8wr
  • 568
    • my home page
« Reply #8 on: February 09, 2005, 08:55:39 AM »
Thanks mine r from a 79 fullsize bronco i know were 3 broncos arounf that year r sitting. i'll try to take some pics this weekend as the build progresses. thanks for the info. for anyone looking for custom links www.rustysoffroad.com hooked me up with 8 fully adjustable links made to my specs with Johnny joints for under $400 including shipping.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #9 on: February 09, 2005, 09:27:58 AM »
i am going to run a kicker3 case to a sammi to eliminate the slip yokes and tom woods high angel drive shafts. i have it all drawn on auto-cad so everything is measured and clearanced just need to bring all to the real world. i am planning on running 4.10 axle gears with a 4:1 lowrange in the sammi case. i figure that should be about right for 37" to 38" tires.stability.
Check this out if you haven't already. Just don't mind the M151 and T90 stuff around the edges. Currently it's setup for what my kick was before the toy axles. You can edit data in here and see your RPM ranges, etc. I think you'll find that you might be riding your clutch when it's on the street with 37's or 38's with the 4.10 gears. 35's should be really good though.
http://www.granitepath.com/friends/kd7hcg/pictures/otherpics/mykick.xls
You'll need Excel.
Heather
« Last Edit: February 09, 2005, 09:32:29 AM by hcgalvin »
Heather Galvin
Offline tracker8wr
  • 568
    • my home page
« Reply #10 on: February 09, 2005, 10:46:01 PM »
thanks heather i might have to go with the 6.5:1 low range because i just got the axles the rear is a 4.10 but the output for the front is drivers side. i think i may use the dana 30 wide trac out of a cj8 it is in my shed i have to go look at itand check the r&p.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline zukizzy
  • 123
  • Give it a bump, see what happens!
« Reply #11 on: February 10, 2005, 02:51:54 AM »
If that is a RR d44 in that bronco I have a d44 from a scout that has a p side drop maybe a trade?
Thanks
Wayne
Clearly a road
Offline tracker8wr
  • 568
    • my home page
« Reply #12 on: February 12, 2005, 06:04:40 AM »
my sas has been postponed until. the dana 30 was short by 4"s so i have to find a wide-trac. hope to have after i get back from wheeling next weekend.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline Chief
  • 678
  • Whaddya lookin at??
« Reply #13 on: February 13, 2005, 01:58:02 AM »
Dunno why I didn't think of the Early Bronco also!
They are great in the Ranger's and Bronco 2's (where I first got into 4 wheeling) and would be perfect in a trackick also, giving it a wider stance also.
I'm going with D44's out of a scout for my SAS (next summer).
