Oxygen Sensor
  • 2315 Views
Offline Zukcrazy
  • 9
  • ZUKCRAZY
Oxygen Sensor
« on: May 22, 2006, 04:40:51 PM »
I need to replace my o2 sensor on my 94' tracker 4wd 1.6 8v
What o2 sensor are everybody using to replace the oem ones  i dont want to spend alot $$ for the oem
the oem has 3 wires- 2 pink wires and 1 black
i need some part #'s and where did you get them from and what wires go to the factory wires
Thanks
TRACKERS RULE
Offline reb
  • 195
  • Victim of CRS--Can't Remember Anything.
Re: Oxygen Sensor
« Reply #1 on: May 25, 2006, 11:25:39 AM »
No responses in several days.  Maybe your name scares people off? ;D  I replaced the O2 sensor on a Toyota several months ago.  I don't recall where I bought mine, but a Google search brought up many sources.   Some sensors were pretty cheap, around $25 or $30, but used splices to hook into the existing connector.  I figured a sensor with the connector already attached would be more reliable.  Mine cost (as I remember) around $85 delivered.  Try the Google thing.  A little bit of research will find you the best deal.
Good luck.
Offline Yoak
  • 577
Re: Oxygen Sensor
« Reply #2 on: May 25, 2006, 11:37:26 AM »
I got one from the zone :'(
And it didn't seem to work very well...also wiring on it was a bit odd, 2 wires weren't specfic...which is odd as oem is...
Offline Jimiweld
  • 234
    • www.fullfusion.ca
Re: Oxygen Sensor
« Reply #3 on: May 25, 2006, 11:48:31 AM »
I just replaced mine a while back, I used the Car Parts Company which is now owned by NAPA. It was a Bosch and the wiring clipped right in. The one from The Parts Source was generic and you would have to use the plug from the old O2 sensor. It's been in for about 2 months now and seems to work fine.
Sorry, I don't have a part number but if need I can call and get it for you.
Offline Zukcrazy
  • 9
  • ZUKCRAZY
Re: Oxygen Sensor
« Reply #4 on: May 26, 2006, 07:52:49 PM »
Thanks For the info everybody
TRACKERS RULE
95XL7
Re: Oxygen Sensor
« Reply #5 on: May 27, 2006, 08:24:37 AM »
I have a brand new 3 wire sensor sitting here,you will have to swap out the connector.
$20 shipped to your door.
Offline trackenator
  • 38
Re: Oxygen Sensor
« Reply #6 on: May 27, 2006, 09:40:19 PM »
I have mine un hooked keeps blowing fuses which also controls the fuel pump (only started this after the body lift(bare wire) runs great,have 200,000 miles on it andrunning 31 in swampers AND stillgetting 24 mpg!
