WEBER 34 DGEC CARB INSTALL NEWBIE PLEASE HELP!!!!!!
  • 3015 Views
Offline MTNMANSIX
« on: May 23, 2006, 05:43:31 AM »
87 SAMURAI,  JUST BOUGHT A 34 DGEC WEBER CARB HAVING TROUBLE LOCATING ELECTRIC CHOKE WIRE.   ALSO STOCK CARB HAD A MANUAL?/ANTIFREEZE HOSES WHICH  I CONNECTED/LOOPED.  ARE THERE ANY MORE ELEC. CONNECTS THAT I NEED  TO MAKE?  OLD CARB HAD A FIVE WIRE CONNECT AND ALSO ANOTHER 4-WAY BUT NEW WEBER ONLY HAS A ELEC. CHOKE CONNECT?  FOLLOWED WIRING DIAGRAMS ? VENT SOLINOID WIRE?  MIX CONTROL WIRE?  VACUUM SWITCHING WIRE?FUEL CUT SOLINOID WIRE?  WHICH ONE IS THE ELECTRIC CHOKE WIRE?
Offline MTNMANSIX
Re: WEBER 34 DGEC CARB INSTALL NEWBIE PLEASE HELP!!!!!!
« Reply #1 on: May 23, 2006, 05:47:34 AM »
HAS ANYONE MADE THIS SWAP?  DO YOU HAVE PICS OF PROPER VAC/HOSE AND WIRE CARB CONNECTS.  SAMMY JUST ISN'T RUNNING RIGHT.   THANX FOR YOUR HELP
Offline AZMIKE
  • 6
« Reply #2 on: November 17, 2006, 07:05:19 PM »
i just intaslled this carb also. cant figure out the elec choke wire either. did u ever figure it out?
87 SAMIURAI
Offline costa 05
  • 206
« Reply #3 on: November 17, 2006, 07:30:12 PM »
Connect a hot wire to the  choke you also have to have a wire going to the the connection under the choke.
when in doubt gas it!!
Offline SamuraiGuy7
  • 80
  • My Samurai
« Reply #4 on: November 18, 2006, 08:22:50 PM »
should have gone with the water choke..thats what i got, in the 32/36. makes it easier (thats what that antifreeze line is for). that way you dont have to worry about that antifreeze line and such, and theres less wires/wiring...why not go with the 32/36 progressive? good carb.
87 Samurai
     4x4
