My first Sammi!!!!
  • 21 Replies
  • 4562 Views
Offline oklak5guy
  • 16
My first Sammi!!!!
« on: May 24, 2006, 06:58:48 PM »
Ok, here is my first thread with the sammi. I just got it last weekend. cant post pics, but it is sweet. Only a little repairable rust, and only has 52000 miles on it. I plan on driving it stock for a while until I do enough research, and save some money.
1st question.
When I start it up and it is cold, it revs really high. For quite a while. It finally smooths out and slows down, but still seems like an erratic idle. But not real bad. Any tips?
2nd question.
If i were do buy all of the engine stuff from Calmini for the 1.3 (Camshaft, headers, exhaust, Weber, etc) How many HP could I look at getting from it? How does this compare to just swapping in a stock 1.6? I only ask this because I am a whiz at bolt on stuff, but do not have the facilities or tools to do the swap right now.
3rd question.
Does anyone have any comments or reviews on the bolt on SPOA kit from Calmini? I think it is like 5 or 6 inches. How is it off road, on road, flex? Does it have decent clearance under the axles? I think I could put it on in my driveway.
I would like to do whatever i need to the engine, add the 5.38 gears, and one of the gearing packages for the Tcase. Maybe some harder axleshafts, wheel spacers, power steering, bumpers/armor, maybe 2" body lift. I would like to run 35" Pit Bull tires.
So with this setup I am talking about, can I drive this setup to work and back and do mild to medium wheeling on the weekends. Mostly trail, mud, and mild rocks. I dont mind having to fix something every once in a while, but would like to build it where it will not break all the time.
Please excuse these searchable questions, but this is my first suzuki, and I want to try to build it right the first time.
Thanks in advance.
Re: My first Sammi!!!!
« Reply #1 on: May 24, 2006, 08:01:58 PM »
By the time you add up the cost of power steering, headers, cam, webber carb.... you could have purchased a 1.6L and had MUCH better power and torque. If you're looking for 5" of lift or more, i presume you're trying to put on BIG tires... and you're going to want a bigger motor.
Check out this thread for engine options:
http://www.zukiworld.com/forum/index.php?topic=12012.0
If you NEED to do something for performance, I'd buy a cam from this guy:
http://www.hawksuzukiparts.com/
Calmini makes good stuff. Can't go wrong with them. Do a search for calmini, you'll find lots of reviews and opinions.
~J~
Offline sidekick 4x4
  • 97
  • sidekick
« Reply #2 on: May 24, 2006, 08:05:55 PM »
if your car is manuel then thats the reason it idels so high bc if it didnt you would stall it all the time bc the engines cold
1990 sidekick,snorkel, 2.5" coil spacers, procomp shocks and strut extenders, 3" calmini body lift, 30" A/T,CHEERY BOMB MUFFLER
Offline oklak5guy
  • 16
« Reply #3 on: May 25, 2006, 03:01:50 AM »
HOw big is the Sammi gas tank?
« Reply #4 on: May 25, 2006, 11:33:13 AM »
Small 10.6 US gal Fuel, we are talking about larger ones over here.
I would skip putting lower gears in and just go straight for a transfer case.  You are most likely going to want one anyways, and it is a lot cheaper then swapping your diffs out.  Not to mention easier.
If your true goal is 35's, I would just look for some Toy axels or something a bit larger to be done with it.  You can could rebuild the Sammy axels to be just as strong as something else, but it would probably cost more in the end.  With the amount I have put into my current axels, I could have bought some Toy's to start out the process.  And I haven't even done anything radical to mine.
If you want to stick with the Sammy axels though, there are some good writeups on swapping out to the larger Calmini axels and Subaru Birfields, or Birfield cups, or those new longfields that should get you through a day without breakage.
You might want to stick with the SOA and 31's to begin with though, and see how it wheels as is.  Especially if it is going to be a DD without a larger engine, like Jeremiah said you will want the extra power and torque with the larger tires.
Then again, I tow a SJ-410 (970cc's of power, feel those 42hp at work!) with a Turbo Diesel, so I may not have the best advice when it comes to DD Sammy's.  :D
Offline oklak5guy
  • 16
« Reply #5 on: May 25, 2006, 09:02:06 PM »
Ok, rethinking. 33" Pit Bulls..............not very tall. Willing to cut fenders. Want a decent ride and want flex. A little more power. Dependable. chime in all you want, this will end up being my build up thread.
On this stock engine, how many MPG should I get? The guy I bought it from told me it gets around 28. doesnt seem right.
« Reply #6 on: May 26, 2006, 12:29:48 AM »
I know people have been happy with the YJ SOA kits available, but I'll let the sammy drivers chime in on road gearing with the 33's.  ;D
Offline oklak5guy
  • 16
« Reply #7 on: May 26, 2006, 07:37:50 AM »
Really curious about the Bolt on SPOA kit from Calmini, as I dont look forward to trying to line up spring perches myself.
« Reply #8 on: May 26, 2006, 10:12:19 AM »
Rocky Road has spring perches that fit on top of your existing pads for your own SOA setup.  You would still need to do something with your steering, drive shaft length (Spacers work) and brake lines (I just moved mine outside the mounting bracket, and slipped a zip tie around it, Hawk Suzuki has extended lines available).
Pad Linkage.
Just make sure they are in stock if you order them, otherwise you might be waiting a while.
« Reply #9 on: May 26, 2006, 06:49:26 PM »
The 1.6 16v is WAYYYYY worth the swap.
Offline oklak5guy
  • 16
« Reply #10 on: May 26, 2006, 07:09:45 PM »
Love those spring perches. Will definitely get those.
Was thinking I may try and run the stock axles for a while. See what kind of wheeling I will be doing. Was thinking 35" tires, because a coworker has a set for pretty cheap. What gears do I need in the axles for 35's?
If I go the way of the 1.6 16v, How hard is it to wire it up?
Offline oklak5guy
  • 16
« Reply #11 on: May 30, 2006, 07:17:30 PM »
Same questions as above? Plus, I cant get the Tcase to shift easily into 2H after wheeling the other day, I was told it was the shifter sheet. Where can I get one and how hard to install?
mudfkr
« Reply #12 on: May 31, 2006, 02:21:45 AM »
I'm just putting Calmini SPOA in mine at the moment, 1.5" springs with shackle reversal. How ever it will  a while before I'm ready to drive it as I'm now waiting on a snake racing hi steer knuckle (http://store.snakeracing.com.au/cache/item-892public.html?cache=no) and I want to mod a few other bits before it goes back together.
The Calmini perches are well designed and give the spring a good solid footing of equal size top and bottom side of the spring compared to my mates R/R kit where the top plate is of a larger size then the perch which is making the spring invert slightly when it's torqued down in place, he's also ended up welding the perch to stop them moving around.
« Reply #13 on: May 31, 2006, 02:43:20 AM »
Go to the Gear Guide on this site. It should be about $20 shipped.
~J~
Offline oklak5guy
  • 16
« Reply #14 on: June 01, 2006, 09:59:11 AM »
I didnt see them in the gear guide.
