Ford Nine inch rear
  • 12 Replies
  • 3958 Views
Offline magiccat
  • 98
  • 94 Sidekick 2.5 spacer lift 30x9.5 mt's
Ford Nine inch rear
« on: May 24, 2006, 07:03:46 PM »
I know this is  probally a dumb question but I am in the dark in this. WHen talking about a Ford 9 in. rear axle; what exactly is nine inches? ??? I can't seem to figure this out. THanks again
Offline the_maplebar
  • 466
Re: Ford Nine inch rear
« Reply #1 on: May 24, 2006, 07:12:15 PM »
It's refering to the 9" ring and pinion in the differential.  I believe the pinion gear is 9 inches
Offline magiccat
  • 98
« Reply #2 on: May 24, 2006, 07:15:47 PM »
So that's the only difference between the stock sidekick axle and the ford 9 in. axle?
How does this make such a big strength difference?
  • 466
« Reply #3 on: May 24, 2006, 07:20:46 PM »
Well since the R&P are bigger they are stronger too, but I believe it has more to do with the axle shafts and splines.  The shafts are at least 30-50% larger in diameter, which is why they are stonger.
Offline joe_and_jeep
  • Why have a Rev Limiter and not use it?
« Reply #4 on: May 24, 2006, 07:51:05 PM »
The ring gear is 9in diameter.  And is stronger due to size.  31spline shafts compared to 26.  Also the pinion uses 3 pinion bearings, helping reduce deflection.  And upgrade parts are EVERYWHERE.  There is so much aftermarket for these axles.
96 Tracker DD - 2in, 30s
95 Tracker Under the Knife - 4.3V6 - Rest Unknown
91 Jeep YJ Full Cage, Tri Link, D44/D44 35s
84 Jeep XJ Doubler HP44/9IN 35s
« Reply #5 on: May 24, 2006, 08:03:01 PM »
YOu'd need to have the axles custom cut though wouldn't you?
~J~
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #6 on: May 24, 2006, 08:45:11 PM »
~J~
If from an older bronco, it's only 2 or 3 inches wider, no need to cut. -plus it's the same bolt pattern  ;)
« Last Edit: May 24, 2006, 08:47:21 PM by Uncivilized »
  • 466
« Reply #7 on: May 24, 2006, 08:45:18 PM »
Here's the article on swapping a 9" under a TracKick
http://www.zukiworld.com/month_070103/feature_hagen_ford9inch.htm
Axles from a 73 Bronco were used and are only 3" wider than stock.
Oh and to illustrate the strength difference, here is the pick of a Suzuki 5.83 pinion gear next to a Ford 9" 5.83 pinion.
Offline locjaw
  • 2045
  • 22
« Reply #8 on: May 24, 2006, 08:55:54 PM »
WOW :o
that picture really puts it in perspective, dont it ;)
jason
Offline Yoak
  • 577
« Reply #9 on: May 24, 2006, 09:14:32 PM »
Just a bit more beefy   ;D
Offline magiccat
  • 98
« Reply #10 on: May 24, 2006, 11:06:50 PM »
I see now! ;D
« Reply #11 on: May 25, 2006, 05:58:13 AM »
I dont see a Track/Kick breaking that.  Now you'll have a near indestructable rear.  Whatcha gonna do about the front?
  • 466
« Reply #12 on: May 25, 2006, 07:07:26 AM »
Get an Anvil and use Toyota CV's that you can find at any junkyard  ;D
