Help With camber!!!!!!!!!!
  • 1468 Views
Offline magiccat
  • 98
  • 94 Sidekick 2.5 spacer lift 30x9.5 mt's
« on: May 27, 2006, 12:12:57 PM »
Hello I just slotted the upper strut hole more.
How do I move the knuckle as far as it will go?
Do you hit i with a hammer? Or is there an easier way?
Thanks
Re: Help With camber!!!!!!!!!!
« Reply #1 on: May 28, 2006, 12:31:08 PM »
It should move quite easily, maybe you need to grind a bit off the knuckle?
Offline magiccat
  • 98
« Reply #2 on: May 29, 2006, 01:24:09 PM »
I took my kick to schawab and they got aligned for me. He said it's only 1 tenth of a degree off on both sides. so it should be good. My toe was way out also. That knuckle is hardened steel I thiink it would be pretty hard to trim up. How does your toe move from time to time?
Thanks
