need frunt axel info
  • 1367 Views
Offline wezzlegod
  • 227
  • under construction crowler
« on: May 27, 2006, 12:21:56 PM »
ok its time to upgraid. so i need some knolage. can i buy just the the 26 spline axel and cv with a front trail tough locker? or is the housing for the 22 different than the 26 spline? i went out to h.d.r. and broke my second d.s.axel climbing a ledge. did the first on duron in calico. its getting old swaping and rebuilding my f/diff housings.
oh anyone know if the 26 spider gears will fit into a 22 spline diff. if anyone has a 26 assembly to traid for a 22 spline asembly i have 2 3rds and a 10 bolt rear if you sammy guys want to deal.
ya 5.12s
« Last Edit: May 28, 2006, 06:05:53 PM by wezzlegod »
Offline wezzlegod
  • 227
Re: need frunt axel info
« Reply #1 on: May 28, 2006, 06:06:56 PM »
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #2 on: May 28, 2006, 06:25:54 PM »
Housings are the same.
