Which is longer?
  • 1903 Views
Offline Guardrail
  • 101
Which is longer?
« on: February 10, 2005, 03:34:16 PM »
I was thinking of getting some longer shocks for the rear of my gv.  Drivetrain.com says my gv uses the same rear shocks as the trackick.  So I am hoping somebody can tell me which is longest.  Crown Vic shocks, OME shocks, or Calmini shocks.  Any info very helpful.
Thankyou.
Bri.
Can he say that here
Later,
Guardrail
Re: Which is longer?
« Reply #1 on: February 10, 2005, 04:41:27 PM »
How much longer do you want to go?
« Reply #2 on: February 11, 2005, 04:49:43 AM »
Procomp can supply shocks pretty much whatever length you want.
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #3 on: February 11, 2005, 04:57:37 AM »
Same with Rancho and BDS.
Heather Galvin
Offline Guardrail
  • 101
« Reply #4 on: February 11, 2005, 01:37:32 PM »
I am planning on using the Calmini 2.5" lift in conjunction with perhaps a 2" spring spacer in the front and a 3" in the rear.  I am also planning on lifting the body 2".  I would like to be able to run 31"-32" tires and I don't want to move bump stops unless I can do it with a wrench because I can't weld.  I plan on running many of the trails around Phoenix Az.  I was looking for the longest travel shock without getting overly complicated with any kind of custom one off set up.
Later,
Guardrail
