Tires mounted with pics!
  • 37 Replies
  • 8204 Views
Offline allian
  • 70
  • love zukiworld! all the info you need.
« on: May 28, 2006, 09:32:58 AM »
i am glad to say i finally got my tires!
it took me a while to get my pics posted but here's a few.
there hankook MT's 235/7515, i love um..
able to rip threw just about anything. tires make such a big diffrence!
i'll be posting more pics to come... ;D
« Last Edit: May 28, 2006, 12:02:14 PM by allian »
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: got my tires mounted with pics!
« Reply #1 on: May 28, 2006, 09:45:21 AM »
Lookin' good! 8)
Offline stock93tracker
  • 309
« Reply #2 on: May 28, 2006, 11:19:05 AM »
Nice looking tires!  How much did they run you $$ ??  ANy issues with rubbing?
93 Geo Tracker
-15 x 7 Rims , 235/75/R15s tires
-2" Lift
Jayzuki
« Reply #3 on: May 28, 2006, 11:49:30 AM »
Hankook make decent tires. They make excellent winter tires anyway!!
Looks great!
Offline allian
  • 70
« Reply #4 on: May 28, 2006, 11:50:23 AM »
i lucked out on these tires, got them used, almost new about 85%tread left on them. i got all 4 for only $200 canadian.
i have no issues with rubbing with my wheels fully cranked. if your running stock height 235 would be the way to go.  ;D
MT's rule!
« Last Edit: May 28, 2006, 11:59:19 AM by allian »
Offline Quaddawg
  • 1622
    • My Ebay Store
Re: Tires mounted with pics!
« Reply #5 on: May 28, 2006, 12:54:06 PM »
Cool, now let the air out of those puppies and see how much better they do off road! Try running them at about 10-12 psi off road.
Offline Yoak
  • 577
« Reply #6 on: May 28, 2006, 01:09:46 PM »
I am jealous  >:(
They Look very good, hopefully I can come across a deal like that ::)
Offline allian
  • 70
« Reply #7 on: May 28, 2006, 01:55:55 PM »
10-12 psi...
i've gone wheelin' a few times already they seem to grip really good, but i'm gonna have to try that next time.
« Reply #8 on: May 28, 2006, 01:59:49 PM »
MT's RAWK. Those look real nice on your truck!
~J~
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #9 on: May 28, 2006, 02:27:09 PM »
10-12 psi...
Next time you hit a hill you can barely make it up, spinning and such...   stop and air them down. I ran 10 in my 235's, but I run 0-5 in my 33's...  the difference in traction is almost unbelievable for the unititiated.
Offline allian
  • 70
« Reply #10 on: May 28, 2006, 02:33:00 PM »
10-12 psi...
awsome thanks for advice! i will definitely try that.
 ;D
Offline MKOLSEN22
  • 217
  • Come on 32's
« Reply #11 on: May 28, 2006, 06:40:51 PM »
Are you running beadlocks with that low of pressures?  Or, is the Kick light enough and with low enough torque to not worry about slipping a tire on the rim?  I've ran my 235's down to 20 psi on many occasions but I might need to try going lower.
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #12 on: May 28, 2006, 07:07:40 PM »
I have marked my tires, to make sure I wasn't spinning them at 0..  I wasn't, but yes, you DO need to be aware of that possibility.
You really don't need anymore than 20-23 on the street in the first place.. bet your ride will be a LOT better with less air.. ;)
Don't forget that airing down also lowers your final drive ratio too, not a ton, but every little bit does help, and it also decreases the resistance that rocks and obstacles in your path put up to your tires, it allows the tire to conform to say, a rock, instead of having to "climb" it, it just conforms to it and rolls right over.
There are several very real benefits to driving off road with very low air pressure.
Anymore, I have softened the sidewalls such that I can't run 0 anymore.. I have to have 1 or 2.. at least..
but yeah,  on stiff tires, like my TSL LTB's, you can run them WAY LOW without too much worry, of course, I would LOVE to have a set of Staun internal bead locks.. that would rule, but they cost more than my tires... lol..
It all depends on the tire, you want to run them where they squat real good, but not enough to fold the sidewalls, or bottom out..  each tire is a little different. I had Buckshot mudders in 235x75 and I could run them down to 8 or 9 at the lowest, but they tended to do best at about 10-12.
These LTB's are nearly perfect at 5 psi, but with a spool, I can't run them on the street, they get too much traction, and I am afraid I will twist my axles at the splines.
Give it a try, I was truly amazed at the difference it made on my Tracker, even more than it made on my full size trucks.
The contact patch increases a WHOLE LOT.. I am not sure how much, but it seems like at LEAST twice as much..  in length mostly, but a little width too.
Here is an example:  Taken from an EXCELLENT article here:  (good read)
http://www.4x4now.com/sfjun96.htm
« Last Edit: May 28, 2006, 07:11:41 PM by Quaddawg »
Offline allian
  • 70
« Reply #13 on: May 28, 2006, 09:31:39 PM »
Quaddawg you have a tone of 4 wheeling info. thanks.
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #14 on: May 28, 2006, 10:07:01 PM »
Airing down is offroad 101. Grab yourself a compressor to air up before hitting the road though. The size increase in your contact patch makes a big difference to traction. I used to run 8-12psi in my 31's and never popped a bead but I did get the odd slow leak from $%^in the bead.  I've got internal beadlocks now and no more problems so far at 5-6psi, haven't tried lower. If you have new rubber and particularly if they are LT construction then you will find them pretty stiff but drop the pressure and run around for a while on them and they will soften up nicely.
