Tires mounted with pics!
  • 37 Replies
  • 8427 Views
0 Members and 14 Guests are viewing this topic.
Offline Quaddawg
  • 1622
    • My Ebay Store
Re: Tires mounted with pics!
« Reply #15 on: May 28, 2006, 10:17:01 PM »
Airing down is offroad 101. Grab yourself a compressor to air up before hitting the road though. The size increase in your contact patch makes a big difference to traction. I used to run 8-12psi in my 31's and never popped a bead but I did get the odd slow leak from $%^in the bead.  I've got internal beadlocks now and no more problems so far at 5-6psi, haven't tried lower. If you have new rubber and particularly if they are LT construction then you will find them pretty stiff but drop the pressure and run around for a while on them and they will soften up nicely.
Staun beadlocks??  or what?  What did you pay for them?  I want those badly.
I agree on the airing down being offroad 101, but I am amazed at the folks that just won't do it, or never thought of trying it themselves.. I see it almost every time I go out.  Just trying to spread the word more.
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #16 on: May 28, 2006, 10:27:51 PM »
Yes, and I got mine cheeeap! ;D ;D Picked them up used. Ideally you want to get them fitted by someone who knows what they are doing.
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #17 on: May 28, 2006, 10:40:47 PM »
Yeah, I heard that they can be a little tricky to install correctly..
Man, if I had those, I don't think I would even put valve cores in my tires..   :o
Offline echojeff
  • 414
  • Lo que sea
« Reply #18 on: May 29, 2006, 07:48:22 AM »
I had an old worn down set of p215's, that when aired down to 18-20 psi they started to squat.  Now I have lt 235's and went down to 15psi, and they barely bulged.  But what a diffrence in dirt road ride! I live on a dirt road, so I noticed the diffrence immediatly, and that road in the mountians was much rougher.
 So I guess 10 psi is ok?  Maybe a tire pressure post is in order.
I will try that next time.
Jeff
« Last Edit: May 29, 2006, 11:54:06 AM by echojeff »
95 Kick 4dr JLX.
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #19 on: May 29, 2006, 11:57:45 AM »
It all depends on the tire... just be careful and watch your beads and sidewalls.. Some tires are tougher than others.
Also, take a look at your tracks, make sure you still have a good imprint in the center. when you get TOO low for a particular tire, it will start dishing in the center and actually cutting down on your contact patch, there is a sweet spot for every tire, and  you will find it.
« Reply #20 on: May 29, 2006, 01:33:20 PM »
I know there are some really nice on board air setups out therel... but until I can get one setup on mine... what else can I use? Do those $30 12V compressors from Wal-Mart work well, or would airing up 4 tires burn 'em out?
~J~
Offline wezzlegod
  • 227
  • under construction crowler
« Reply #21 on: May 29, 2006, 04:02:57 PM »
those arnt tires
black 89 sidekick toyota 22re L52 5speed trans w/ duel t cases. toyota axles w/coil springs 4 link double triangle 3 link front, 5.29 r&p, lockers ,35x12.5 tires, rock rails ,custom plate steal bumpers, killer xm sounds ext ext ext
Offline the_maplebar
  • 466
« Reply #22 on: May 29, 2006, 04:46:15 PM »
~J~
Most of them will take forever/burnout on you.  There are a few that are pretty decent, you want to avoid the cigarette lighters and plug them straight onto the battery (more amps).  The SuperFlow MV-50/MasterFlow MF-1050 seems to have a pretty good reputation, and is what I am using.  Here's a couple of reviews on it.
http://www.4x4wire.com/tech/portable_oba/
http://www.gearinstalls.com/pepboys.htm
2002 4DR Tracker V6 ZR2.... 1.5"/2" coil spacers front/rear, BDS Strut Extensions, 235/75R15 Cooper STT... They ROCK!!!
http://www.zukiworld.com/forum/index.php?topic=35.msg111575#msg111575[/url]
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #23 on: May 29, 2006, 06:52:23 PM »
~J~
If you are going to use a portable, make sure you use the ones that Maplebar suggested, at least..  as far as Wal-mart offerings?  They work like CRAP.. takes forever.. they burn out sometimess.
I use CO2... I have a Tippman Instant air that uses a 20oz, and I also have a 20# bottle I use sometimes..  I can fill the 20oz from the 20# too..  very convenient, will also run air tools and turn water into club soda.. lol..
http://leather-working.com/catalog/index.php?cPath=73
Nothing like it.. blows even the high dollar compressors away with speed and convenience, and you can  carry it anywhere, swap between vehicles.. etc...   It is WAY fast, as you have 100 PSI at the hose, you don't need to build up pressure.. Takes me seconds per tire, instead of minutes.
Plus, you can run your ARB that you want (jk...lol) with CO2 also..
« Last Edit: May 29, 2006, 07:08:57 PM by Quaddawg »
« Reply #24 on: May 29, 2006, 07:51:18 PM »
That looks SWEET. Looks like the $25 thing is over (Kragen was blowing their inventory out of them - special price). Cheapest I could find is at target for $55 + $14 S&H. I wonder if I can just get it at the store for same price...
http://www.target.com/gp/detail.html/ref=br_1_4/602-8742843-3648623?%5Fencoding=UTF8&frombrowse=1&asin=B000BM8RT8
« Reply #25 on: May 29, 2006, 07:53:11 PM »
LOL - well, with dual air compressors, and a 2lb tank I can run the ARB's too :)
~J~
Offline echojeff
  • 414
  • Lo que sea
« Reply #26 on: May 29, 2006, 09:37:10 PM »
~J~
I have the $20 compressor from walmart...... its not worth looking at.  I had 215's and it took 10 min per tire to go from 18psi to 30psi, and it has a 20 min duty cycle (20 min on, 20 min off). So I had do drive for 20 minuets to let the thing cool down. >:(
I got a 20% off coupon at 4wheel parts and got the mv50 for $55.  I just used in on my new 235's and went from 15psi to 30psi in about a minuet.  Huge difference.  Now I need to test out lower pressures for the street and maintain mpg.
Jeff
95 Kick 4dr JLX.
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #27 on: May 29, 2006, 10:44:51 PM »
~J~
Yeah, but I still swear by my portable instant air.. try running an impact with a 2 gallon tank.....
« Reply #28 on: May 30, 2006, 01:07:45 AM »
~J~
You could mount a paintball cannon to your rig too ;)
~J~
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #29 on: May 30, 2006, 04:27:31 AM »
Now you sound like my son!!
