Sammi VS trackick brakes....
  • 1780 Views
Offline Chief
  • 678
  • Whaddya lookin at??
« on: February 09, 2005, 08:07:56 PM »
Just curious if the calipers and rotors are ther same/very similiar. Going rear discs soon, and finding used calipers/rotors are MUCH easier for a trackick then for a sammi!
I'm using the brackets from Trail Tough to bolt everything on.  8)
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
Re: Sammi VS trackick brakes....
« Reply #1 on: February 09, 2005, 09:03:03 PM »
As far as I know the calipers are the same, rotors I don't know. Over here everybody with a sammy uses trackickvit calipers because they are easier to find.
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline Natebert
  • 1098
« Reply #2 on: February 10, 2005, 02:44:13 PM »
We put 4 door vented rotors and calipers on our Sammy knuckles with only slight grinding on the dust shield.  (they fit right up)
The only issue is the bleeder, gotta take the caliper off the truck to bleed them as the bleeder is now at the bottom when mounted on the truck.
~Nate
« Reply #3 on: February 10, 2005, 05:19:58 PM »
Nate, did you try switching sides with the
calipers ???  might solve your problem
Offline Natebert
  • 1098
« Reply #4 on: February 11, 2005, 02:49:29 AM »
Nate, did you try switching sides with the calipers ???  might solve your problem
Well DUH!  Good thing I don't have that front end anymore...
I only bleed them once, when I put the calipers on the first time, so it wasn't a major loss for me.  But I bet if they were swapped around it woulda worked fine.  (minus the extra length needed in the brake lines)
~Nate
