need help with tsb- recalls
mozone
May 31, 2006, 06:58:27 PM »
can someone direct me on where to fine the tsb/ recall info on a 2001 zr2 tracker? i have a rattle in the front timing chain area and rememberd the was a tsb or recall on this can anyone help? thank you, mozone.
the_maplebar
466
Re: need help with tsb- recalls
May 31, 2006, 08:30:32 PM »
You can search for a recalls, and a description of TSB's at NHTSA.
http://autopedia.com/html/NHTSA.html
Last I checked Chevy never issued a TSB for the timing chain, they issued a TSB for the valve lifter being excessively noisy because they are not adjusting properly. I know
. Unfortunately since it's a TSB and not a recall, it will cost you a nice chunk to have it taken care of.
http://www.zukiworld.com/forum/index.php?topic=35.msg111575#msg111575
[/url]
mozone
June 01, 2006, 08:35:34 PM »
thanks will check into it. think it could be the water pump that is the only other mild issue i have with this truck. t-stat out but it still reads half way on the gauge.
