manual gear box fluid change on GV
  • 2791 Views
Offline Maroon Monsoon
  • 876
« on: May 31, 2006, 11:34:17 PM »
where is the plug to fill it? I think I've spotted the drain plug before. and also, I think I saw a plug on the side, may be the fill hole and I was thinking it would be like an axle and also the tranny oil on my quad where you fill till it runs out a bit and hurry to get the plug back in... am I correct?
any help is welcome and appreciated, I am 600 miles past due on doing this if it's every 30k you are supposed to do this like the stuff I found said
thanks
Offline beerman
  • 339
  • Suzuki 4x4 Norway
    • www.tristania.com
Re: manual gear box fluid change on GV
« Reply #1 on: June 01, 2006, 02:43:31 PM »
i can see in the manual, my gearbox lies on the floor in the shop :-[
Offline beerman
  • 339
  • Suzuki 4x4 Norway
    • www.tristania.com
« Reply #2 on: June 01, 2006, 04:03:55 PM »
thanks
filling plug is on the right hand side, as i can see on the poor drawing in the manual.
if i remember correctly, it is at the right side.
1,5 Litres in transmission, 1,7 in transfer. use 75w-90 oil (HIGHLY RECCOMENDED in manual)
tighten plugs 23NM/2.3KG/17,0lb-ft
caution: *oil must not be poured trough gear shift control lever part.
              *do not loosen or remove reverse idle gear shaft bolt
use sealant 99000-31110 on plugs
hope this helps.......
  • 876
« Reply #3 on: June 01, 2006, 10:10:22 PM »
thanks you, it does help
Offline blacknight
  • 987
    • Gonzookin
« Reply #4 on: June 02, 2006, 11:09:43 AM »
Take the fill plug out frist then the drain plug.  I've seen people drain something and they can't refill it. Then your SOL
Geogre
  • 876
« Reply #5 on: June 02, 2006, 02:07:39 PM »
that definately sounds like a good idea, thanks
