Do all the auto shift sidekick have the same gearbox with 4 gears and overdrive?
  • 2004 Views
Offline garbage!!!
  • 63
  • IFS PRIDE!!!
    • my truck's zukiworld page
Hey guys, I want to know if all the 4 gear auto gear boxes that come on the sidekick are the same?
I know suzuki used at least two kinds, one with the 3 gears that comes with the 3d and the 4 gears that comes with the 5d, are there any other diferences or diferences between models?
             Thanks
                 Gui
mudding aroung : ) in counryside São Paulo.
3 speed trans was a GM TH180
The 4 speed auto is a Asine (sp)
and has electronics, different but
both will work with the right parts
and computers
Offline sergi
  • 307
The spelling is Aisin ;)
My GV also has an Aisin gearbox, though its maual.
Suzuki Grand Vitara 3dr TurboDiesel
Barcelona, Europe
Aquesta és la meva màquina. Creus que em pots seguir?
Offline wolf66
  • 193
i just replaced my 4sp auto ('96) and the tranny guys said it was a "Toyota" made tranny.......
Does Aisin make the Yoda trannies?
'96 Suzuki X90-4" lift-snorkle-30x9.5's on 8x15 wheels-5.12 gears-winch-added rear seat-DT header-PioneerMP3-CB-GPS-roof rack-rear mounted full size spare
Yes, Aisin makes Toy Trannys as well as
quite a few others, when we cleaned and
serviced my brothers 4 door, we researched
until we found the right model, it took a rebuild
kit for a Toyota trans, and all  the bits and parts
fit great, even had instructions to help.
Offline echojeff
  • 414
  • Lo que sea
And I thought I was the only one that had a hard time speling....... ;D
Asian un less you are speaking about a company.....
Aisin Seiki Co., Ltd. (Aisin, AISIN SEIKI CO., LTD.), TYO: 7259 , a subsidiary of the Toyota Group, is specialized in the creation and production of components and systems for the automotive industry. Aisin Seiki was founded in 1949 and currently supplies transmissions for many auto manufacturers.
  There are various 'brands' in the holding, spawned after the companies that got major recognition in their area of specialisation:
Aisin AW (Aisin-Warner) � automatic transmissions � see List of Aisin transmissions
Aisin AI � manual transmissions � see List of Aisin transmissions
Advics, Hosei � brakes
IMRA � intelligent transport systems
Aisin is also one of the major player in the Aftermarket. This division is distributing the following products : - clutches - water pumps - hydraulic parts (clutch, brake)
I learned somthing today!
Jeff
95 Kick 4dr JLX.
