AHHHHHH!!! It Broke :(--NEW PICS
  • 16 Replies
  • 4204 Views
Offline tOnKa TrAcKeR
  • 264
  • support our troops
    • Cardomain site
« on: June 03, 2006, 04:21:00 PM »
Well today I was coming back from looking at a X-90 that is for sale here, I was on the interstate goin about 60 and the rear end got real Squirelly (sp?).  Well I thought i just hit a puddle and was hydroplaning a little ( it has rained most of the day) So I slowed down but it was still there so I pulled over and This is what I saw :'( :'( :'( :'(.  So after a $125.00 tow bill (which is not too bad seeing as i had to get the tracker towed on a roll back for 80 miles) I am putting the rearend out of the 92 in now.
« Last Edit: June 04, 2006, 07:16:40 PM by gmj2fast »
Offline urbanwheeler
  • 696
Re: AHHHHHH!!! It Broke :(
« Reply #1 on: June 03, 2006, 04:39:34 PM »
I have never seen an axle break like that. I have seen the halfshafts fly out due to broken c clips and broken axleshafts, but I have never seen the axle housing itself break :o. Maybe you should buy or fabricate an axle truss for the other axle you are replacing it with. If that happens in the middle of nowhere, it could equal total damnation ;)
Offline biker
  • 730
  • It's a sickness I tell ya
« Reply #2 on: June 03, 2006, 05:49:12 PM »
I would call the suzuki dealer because I believe I read some where that there was a problem with the welds on some of the rear housings and it was covered under a recall. Worth looking into anyway
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
  • 264
    • Cardomain site
« Reply #3 on: June 03, 2006, 06:03:06 PM »
The only recal relevant to my tracker was the front seat belts (acording to GMC anyways)
Offline biker
  • 730
« Reply #4 on: June 03, 2006, 06:23:12 PM »
Bummer, I'll have to see if I can remember where I saw that and what years it applied to ???
99 Vitara 2wd
10 Gr Vitara
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #5 on: June 03, 2006, 08:28:16 PM »
Try:
http://www-odi.nhtsa.dot.gov/cars/problems/recalls/
Personally, I'd write it up as offroading wear and tear and move on.
Pretty spectacular failure though.  Thanks for the pics!
Ack
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #6 on: June 03, 2006, 09:50:22 PM »
Ive seen several very bent trackick rear axles but never a broken one!  :o
Mike
Offline Yoak
  • 577
« Reply #7 on: June 03, 2006, 10:38:57 PM »
Wow,
glad your ok and nothing else happened!
Offline biker
  • 730
« Reply #8 on: June 03, 2006, 11:05:03 PM »
Thanks for the link Ack, it was the 94's that had the axle weld problem
99 Vitara 2wd
10 Gr Vitara
Offline razorhead
  • 6
« Reply #9 on: June 04, 2006, 07:59:29 AM »
Looking on the pictures tho that is a SERIOUS POS weld, a blind mice would probably welded it better  8)
  • 264
    • Cardomain site
Re: AHHHHHH!!! It Broke :(--NEW PICS
« Reply #10 on: June 04, 2006, 07:20:44 PM »
well i figured i would post some pics of my progress..I dont know why i just did. So here are the pictures of my truck and the rear end coming out of the parts truck.  Everything was going pretty good then when i went to take the shock off of the axle from the donar truck and CRAP the shock mount was bent all to hell in the rollover. Time for a crowbar and hammer ;D
  • 264
    • Cardomain site
« Reply #11 on: June 04, 2006, 07:22:04 PM »
heres some more
  • 264
    • Cardomain site
« Reply #12 on: June 04, 2006, 07:23:29 PM »
and some more......heres the pic of the bent shock mount and one of the new axle sitting under the truck
« Reply #13 on: June 05, 2006, 12:28:41 AM »
Good thing you got that rolled one from your neghboor. Like others have said I have never seen one break there before. ???
Offline kozaz
  • 168
« Reply #14 on: June 05, 2006, 07:28:29 AM »
What size tires you running?
