fiberglassing?
  • 2632 Views
Offline sidekick101
  • 128
  • best site on the net
fiberglassing?
« on: June 09, 2006, 01:14:47 PM »
anyone know how or know a site that gives tutorials on how to do fibergalssing as in sub boxes and interior parts. generix, i kwno you have to knwo somthign about it man. thax everyone
1993 sidekick JX, 2 dr, soft top, automatic,
Offline Uncivilized
  • 1469
    • Car Domain
Re: fiberglassing?
« Reply #1 on: June 09, 2006, 06:43:48 PM »
I've done fiberglass enclosures before, what are you planning to build?
I seldomly use fiberglass mat, I always used a stretchy felt like material from a faberic store and soak it with the fiberglass resin, It's easier to work with, it stretches for making nice tight shapes and soaks up a lot more resin than fiberglass mat, which makes it more solid with a one-time application.
Here's the steps I do: I build structures/skeletons of what I want with MDF wood, and whatever other material. I then make sure it fits in the location with a little room all the way around to allow for the stretchy material, bodyfill, and covering(vinyl or acustic carpet) Then I stretch the material around the structure, stapling/hot glueing it to the wood, making sure there's no creases. I then mix up some resin in a cut-down empty 4L washer fluid container, I mix it hot(it's pretty humid around here so using more hardener than specified cures it faster) Then I use large dollar-store paint brushes to apply the resin the the fabric soaking it well. I have a beer during the curing time. Then it's ready for body filler to smooth it, and add shape, using body fill shavers, I smooth it off before the body fill fully hardens. Then sand, sand sand, test fit, add body fill, sand sand sand. at the end, it's either ready for vinyl, carpet or even paint.
If you want to copy a panel, or get a certain shape into a cavity in the vehicle, you cover it with 3m masking tape, twice, overlaping your tape edges. The fiberglass resin won't stick to the masking tape(i found using cheap tape, the resin will leak through and stick to whatever is behind there and make a huge mess, I only use 3m now) depending on what your doing you can make a frame from MDF or something, and do the same as above, lay material stretching it, hot glueing it, and soaking it in resin.
« Last Edit: June 09, 2006, 08:45:48 PM by Uncivilized »
Offline keith
  • 1176
Re: fiberglassing?
« Reply #2 on: June 09, 2006, 07:38:03 PM »
Here is how not to do fiberglassing. ;D
Actually it serves its intended purpose.
Offline Carnage
  • 2453
Re: fiberglassing?
« Reply #3 on: June 09, 2006, 09:44:28 PM »
*smiles*
this guy did a pretty good with his site
http://web.njit.edu/~cas1383/proj/main/
this ones not bad either
http://www.hotrodders.com/forum/fiberglass-tutorial-52028.html
enjoy!
X32...................X32CarDomainPage...................X32
...................RyouBakua|removethispart|@Hotmail.com..................
Help me Heal!!!!!! CLICK HERE!!!!!!!!!!![/color]
« Last Edit: June 09, 2006, 09:48:35 PM by Gen-Erix »
Offline sidekick101
  • 128
Re: fiberglassing?
« Reply #4 on: June 09, 2006, 10:22:54 PM »
sweet. all great tips thanx evereyone. i wanna build a deual 10 inch box with 6x9 holders in the top for the kick. so any material works well tahts not to thick? and and place u all buy you resen or hardner from?
Offline Uncivilized
  • 1469
    • Car Domain
Re: fiberglassing?
« Reply #5 on: June 11, 2006, 01:06:45 PM »
Do you mean you want to have 2-10" woofers and 2-6x9's in the same enclosure? I wouldn't recomend this - the woofers build more air pressure and will throw off the 6x9's and make them floppy.
Also, if you just want a basic box, you can just build it out of 3/4" thick MDF(medium density fiber) board. I've gone to Home Depot with dimensions of pieces I needed to build a box, I purchase a 1/2 sheet(4'x4', or whatever size I needed) and have them cut it on their wall saw, $1 per cut, well worth it on their profesional saw, better than my Sears brand ;) I then took the pieces home, pre-drilled all my holes, glues and screwed it together, them use 3M spray adhessive and put on some trunk liner, or accustic carpet from a car audio shop.
If you want to see some fiberglass work and how shapes are made, check out alpines website, view the "install photos" arround photo 20 is where it starts.
http://www.alpine-usa.com/en/fun/P-Lot/Corp-Vehicles/06-Sinster6/
« Last Edit: June 11, 2006, 01:16:56 PM by Uncivilized »
Offline sidekick101
  • 128
Re: fiberglassing?
« Reply #6 on: June 11, 2006, 01:39:50 PM »
the subs and 6x9s are gonna be in the smae enclouser but be 2 seperate copartments. just doin this way for the secuirty of no snatch and grab as easy for when the soft top goes on.
