Newbie question
  • 9 Replies
  • 3220 Views
Offline SKAsammy
  • 79
  • 1991 samurai
Newbie question
« on: June 15, 2006, 02:45:11 AM »
I've driven my stock 91 samurai for a while now.  I was wondering what else should be done besides a lift, to run 31's?  Gears, power stearing, 1.6?  Take it easy on me now, Im new, been around samurai's for a while but not any that are lifted or modified.  Anything would help thanks
1991 SAMURAI
6"spoa
2" body  lift
8000 lb winch
30/9.5/15 BFG all terrains roll on bedliner in and out homemade bumper 1996 Silv. 4" lift 35's many mods
Offline Jimiweld
  • 234
    • www.fullfusion.ca
Re: Newbie question
« Reply #1 on: June 15, 2006, 04:28:34 AM »
I found that after the budget 3" body lift I was fine for clearance with a little trimming inside the front wheel wells. I then did the 1.5" coil spacers from Sky and everything clears fine. Mine is a 3 spd automatic and I haven't regeared yet, i have the gears sitting there, I just haven't done it. My actual tires are pretty bald and measure closer to 29-30" in diameter. I find that it runs good on the highways, a little sluggish in comparison to before. I did notice that when off roading and climbing really steep long inclines that it won't spin the tires nearly as well as before, so I definitley want to get those gears in there for off roading.
Offline locjaw
  • 2045
  • 22
Re: Newbie question
« Reply #2 on: June 15, 2006, 07:32:25 AM »
all of the above ingredents will make a really nice samauri ;D
jason
Offline Yoak
  • 577
Re: Newbie question
« Reply #3 on: June 15, 2006, 08:29:13 AM »
A common upgrade is a 1.6 engine swap as well, I would do my lift and tires first though
Offline SKAsammy
  • 79
  • 1991 samurai
Re: Newbie question
« Reply #4 on: June 15, 2006, 03:59:07 PM »
Thanks for the info guys and or gals, now i just need to figure out what im gonna do for a lift, spoa for sure but where to get it... ::)
1991 SAMURAI
6"spoa
2" body  lift
8000 lb winch
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: Newbie question
« Reply #5 on: June 15, 2006, 04:18:37 PM »
Breeze Industries.  They have everything as a kit or separate except maybe the brakelines...  It's the first major mod that I made on my '88 Samurai.   BTW, the first post is from a tracker owner so springs spacers probably won't apply to you ( ;D  sorry).
Body lifts have a tendency to put the center of gravity higher on a Samurai -- especially so if you follow it with an SPOA later on. No point in looking for trouble if your truck is a daily driver.
Ack
Offline SKAsammy
  • 79
  • 1991 samurai
Re: Newbie question
« Reply #6 on: June 15, 2006, 04:40:48 PM »
Breeze Industries sounds decently priced but im still not sure about some stuff... Besides shocks and brake line extensions, what else will I need if i just get the basic SPOA kit, it comes with...
spring perches
u bolts
shock mounts
drive shaft spacers
it says drop draglink steering, crossover steering system, and new tie rod ends are required... also it doesnt say if any other hardware is required, does anyone know if the spring perches are bolt on or weld on? thanks
1991 SAMURAI
6"spoa
2" body  lift
8000 lb winch
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
Re: Newbie question
« Reply #7 on: June 15, 2006, 10:06:47 PM »
You could go to sky-manufacturing.com and get their SPOA with OTT steering fix. only things you will need to buy will be lower front shockmounts and shocks.
$380 for lift kit
I run this with 31's without a problem. I would also get lower rear shockmounts
this was the cheapest  SPOA with a steering fix that I could find.
If you have a bunch of money to spend I would go for this lift
www.trailtough.com
this is the wrangler spring lift kit.
Kit includes:
Front YJ mounting kit with Missing Link
Rear YJ mounting kit with Missing Link
Knuckle Over Steering
Urethane bushings with steel sleeves
Extended brake lines
1 extended slip yoke - exchange - core charge $35.00
2 one inch driveline spacers
Front and rear lower shock mounts
1 pair front upper shock towers
2 pair adjustable spring perches
4 Doetsch Tech 8000 prerunner shocks
Item #YJS0-300 Price $1258.00
Core charges $35.00
Only thing to buy is stock wrangler leaf springs should be about $100 from any jeep 4x4 shop.
if you want to see a some pictures of my before and after shots
http://www.reachone.com/bashams/Suzuki/Zuki/
Mean Green Wheeling Machine
Offline SKAsammy
  • 79
  • 1991 samurai
Re: Newbie question
« Reply #8 on: June 16, 2006, 02:12:32 AM »
That does sound a lot better but i dont have that kinda cash, Ill probly go for the one you run.  Are those bolt on spring perches or weld on?
1991 SAMURAI
6"spoa
2" body  lift
8000 lb winch
Offline bashzuk
  • 784
Re: Newbie question
« Reply #9 on: June 16, 2006, 07:13:00 PM »
They are weld on but they match up perfectly to the old ones just grind down the metal to have a good surface to weld on and just drop them in place on top of the axle.
