backspacing?
  • 2242 Views
Offline ddevil
  • 155
backspacing?
« on: June 17, 2006, 06:34:47 AM »
can anyone explain backspacing to me?  in layman's terms perhaps?  i know it has to do with wheel offset but not sure how it works...
milk
'95 geo tracker 2dr 5spd soft top with 2" suspension lift
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: backspacing?
« Reply #1 on: June 17, 2006, 09:28:16 AM »
It's the measurement taken by laying a straight edge across the inside bead of a rim and measuring from the straight edge to the wheel mounting surface(lug nut area)...
Offline ddevil
  • 155
Re: backspacing?
« Reply #2 on: June 17, 2006, 10:08:31 AM »
ahhh, icy.... that clears alot up.  thank you.  so the more backspacing the farther out the tire will sit right?
milk
Offline Flork
  • 40
Re: backspacing?
« Reply #3 on: June 17, 2006, 10:29:11 AM »
Close, but actually its the less backspace you have, the more the wheel will stick out. Wheel width also plays a factor in how far the wheel will stick out as well.
91 2dr., 3spd auto, 5.12's, 30x9.5 BFG AT's on 15x7's, Calmini exhaust and plates.
Offline ddevil
  • 155
Re: backspacing?
« Reply #4 on: June 17, 2006, 11:04:37 AM »
oh yeah, duh, i just reread digger's post.  'inside bead'  :P
milk
Offline Flork
  • 40
Re: backspacing?
« Reply #5 on: June 17, 2006, 09:41:19 PM »
 ;D Don't worry, its pretty confusing sometimes...I'm new to this as well.
I've learned a ton just comming here every morning and reading the posts on this board.
