flush
  • 12 Replies
  • 3244 Views
Offline ibhuktonfoniks
  • 43
flush
« on: June 18, 2006, 04:42:50 PM »
whats the best way to backflush a cooling system? ??? thanks.
Offline noff21
  • 32
  • Find them... Please don't grind them.
Re: flush
« Reply #1 on: June 18, 2006, 08:15:12 PM »
Spend 5 dollars on a Prestone Flush kit at the auto parts store.....
Install on the heater hose..... install a garden hose...... and blow away.
90 Samurai 4" lift finally installed.  Now it's time for some good tires.
Offline crikeymike
  • 713
    • http://www.wazuks.com
Re: flush
« Reply #2 on: June 19, 2006, 03:19:02 PM »
....Or disconnect a heater hose, connect a garden hose, and blow away.  Then re-install heater hose.  Those junctions in the kits crack all the time after a few years.  Working in an auto parts store in the past, i used to sell replacements all the time cause they cracked from heat.  They are a pretty good idea though, but you have to cut the original heater hose to install it.
1993 4-door Sidekick
4.24:1 t-case
  • 43
Re: flush
« Reply #3 on: June 19, 2006, 06:46:00 PM »
could you unhook hoses where heater core hooks up and plug adapter there? do you take thermo out and then where does dirty fluid come out rad top?
Offline crikeymike
  • 713
Re: flush
« Reply #4 on: June 20, 2006, 12:18:24 PM »
I normally disconnect the lower rad hose (to flow more volume), and the cap of course, then flow thru a heater hose or the t-stat housing and let it all flow out.  Usually when i have the radiator out to do a timing belt i'll backwash it thru all the disconnected upper and lower hoses.  It doesn't take too much to get it clean enough.
4.24:1 t-case
Offline SnoFalls
  • 1358
Re: flush
« Reply #5 on: June 20, 2006, 12:47:38 PM »
I've also always just flush from the upper hose out the bottom hose (and yea, pull the thermo). I, usually hook a hose to bypass the heater box and flush it independently as well.
  • 43
Re: flush
« Reply #6 on: June 20, 2006, 05:01:53 PM »
i bought the kit but cant tell which heater hose to use the top or bottom on a 92 kick? sorry bout all the questions but thanks for the help.
Re: flush
« Reply #7 on: June 20, 2006, 07:47:00 PM »
x2
  • 43
Re: flush
« Reply #8 on: June 21, 2006, 08:17:11 PM »
didnt help. oh well new rad to be here in the morn. i guess 4.00 was worth a try to save 130.00
Re: flush
« Reply #9 on: June 22, 2006, 01:52:24 AM »
I did the same thing :)
I decided to get a 3 core - appairently that's overkill 'cause engine has a hard time getting to temp - even in 90F+ weather. Needle stays 1/2 way between "bottom" and the first mark... and engine keeps cold-start high RPM rev for a WHILE. And... my clutch fan is DEAD. So... sick with a stock 2 core Radiator! Not shure what I'm going to do this winter... need to find a way to heat my zook back up!
  • 43
Re: flush
« Reply #10 on: June 22, 2006, 11:06:56 AM »
cardboard in front of the rad used to work. might give it a try.
  • 43
Re: flush
« Reply #11 on: June 22, 2006, 05:40:20 PM »
rad did the job. took her out today with uper 90s high humidity and ran her hard to town then in traffic driving. never got past one third of gauge ;D. not a bad 130.00 spent.
Offline jzap
  • 515
  • How difficult can it be?
Re: flush
« Reply #12 on: June 22, 2006, 09:01:06 PM »
On my old Gremlin, we used to stick a pizza box in front of the radiator to get it to heat up in the winter.  Ahhh, the good old days...
Jim Z.
66 Apache camper
