need help
  • 1557 Views
Offline HAWAIIBUILTZUKI
need help
« on: June 24, 2006, 04:22:20 PM »
i have a sj410..im trying too remove the brake line on the rear axle..got any ideas need help..asap thanks
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: need help
« Reply #1 on: June 24, 2006, 05:40:36 PM »
Try a can of WD-40, PB Blaster or Liquid Wrench (the best choice) and a 10mm brakeline wrench.  A brakeline wrench is like an open-ended wrench except the open-ended gap is only large enough to slip the brakeline through.
In case I am wrong about the fitting size, try a metric wrench until you find the proper fitting size, then get the same-sized brakeline wrench.
All the above are available at most auto parts stores.
Regular open-ended wrenches can flex open and booger up the fitting.  Using an SAE (english) wrench will also booger the fitting because they fit too loosely.
Soak the fitting and after a few minutes, crank on the fitting with the wrench.
Good luck!
Ack
