T-Case pops out of 4HI......common problem?????
  • 3163 Views
Offline zuki4x4chick
  • 7.17 gears. ;)
    • Rev Parts
« on: June 30, 2006, 08:48:06 AM »
I tried searching...............
Our GV T-case is popping out of 4 Hi (mainly 50km speed logging roads bumpy conditions)
HELP............Any info REALLY appreciated...........Thanks 8)
Candace
02' XL-7 Limited , 1 ton axles & 37's, the list goes on......
Suzuki is my weakness.........
Offline thrash
  • 54
  • thrash thrash thrash
Re: T-Case pops out of 4HI......common problem?????
« Reply #1 on: June 30, 2006, 12:44:46 PM »
yea, i had the same problem
jeeps are like tampons
every pussy needs one
http://www.cardomain.com/ride/2295298
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #2 on: June 30, 2006, 04:35:38 PM »
So what did you do?
Offline thrash
  • 54
« Reply #3 on: June 30, 2006, 07:48:35 PM »
well
as soon as i put in the manual hubs
it hasnt popped out of gear
not yet anyways
Offline IanL
  • 466
« Reply #4 on: July 01, 2006, 02:18:16 AM »
well
not yet anyways
So is that with the hubs disengaged, or engaged???  If they were disengaged, 4Hi=2Hi, so no effect.
Offline thrash
  • 54
« Reply #5 on: July 01, 2006, 02:36:09 AM »
right right
with the hubs engaged
  • 7.17 gears. ;)
    • Rev Parts
« Reply #6 on: July 01, 2006, 10:45:41 AM »
I have seen different complaints (online) about the 4WD systems (mainly the vacuum hose to the front diff issue)............But not too many about the t-case thing.........
I suppose I will try it after we throw some manual hubs on..........Thanks
Offline IanL
  • 466
« Reply #7 on: July 01, 2006, 03:47:09 PM »
...with the hubs engaged
Have to say that, with the hubs engaged, it should be no different to having the drive flanges.
The usual causes of jumping out of gear are worn gears or bearings, worn shift mechanism, weak or broken springs in the box or maybe a circlip.  So the cure is probably going to need a strip down of the TC.
