rear shocks lower bolt???
  • 1956 Views
Offline ddevil
  • 155
« on: June 30, 2006, 06:51:38 PM »
ok, what's the trick to getting the lower bolt out of the rear shock?  i've already snapped the rear right one but still can't get the bolt out to remove the shock and i've already removed the top nuts off the shocks and even the nut off the lower bolt but i can't get the bolt out.  i tried pressing it out with a c-clamp but it wouldn't budge.  i can't get to it to tap it out either.  so anyhelp here short of a sawzall???
mike
'95 geo tracker 2dr 5spd soft top with 2" suspension lift
Offline pcguy
  • 343
  • 1996 Tracker 4x4
Re: rear shocks lower bolt???
« Reply #1 on: June 30, 2006, 07:34:22 PM »
I had to use a cutoff wheel and cut both ends of it off to get it out on mine.....
not a fun process but it worked :)
the other side came out fine, must have been less corrosion or something....
Offline ddevil
  • 155
« Reply #2 on: June 30, 2006, 07:39:55 PM »
oi, icy... thanks
Offline pcguy
  • 343
  • 1996 Tracker 4x4
« Reply #3 on: June 30, 2006, 08:28:44 PM »
if you have a harbor freight store nearby, they have a 30,000 rpm die cutter for $20 and some wheels to go with it for another $5
Offline ddevil
  • 155
« Reply #4 on: June 30, 2006, 11:20:49 PM »
nope, but i do have a sawzall... will that cut it?
Offline pcguy
  • 343
  • 1996 Tracker 4x4
« Reply #5 on: July 01, 2006, 04:27:33 AM »
i dont know, will it cut a bolt? and if so, can it do it without cutting the shock mount with it?
Offline ddevil
  • 155
« Reply #6 on: July 01, 2006, 01:14:08 PM »
i sawzalled it :D  took me a couple blades for the bolt i snapped but it cut right through the other bolt like butter.  i love my sawzall.
mike
