2.0 no spark cyl #2
  • 2292 Views
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
2.0 no spark cyl #2
« on: July 02, 2006, 10:51:34 PM »
I cant figure out why I have no spark on my 99 tracker. I swapped coil packs and cam sensor  but still no spark. Has anybody else ever heard of this?
Mike
Re: 2.0 no spark cyl #2
« Reply #1 on: July 02, 2006, 10:57:04 PM »
2 coil packs or 4 coil packs?
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #2 on: July 02, 2006, 11:00:52 PM »
It has 4. 1 for each cyl.
« Reply #3 on: July 02, 2006, 11:07:12 PM »
Try the connector, test for connection
You could try to fire the coil from,   ohh never mind
that only would work if it were wasted spark system
That would use 2 coils, and they would each feed 2
spark plugs, they fire on the compression and exhaust
cycles, but this system isn't going to work like that.,
My best guess would be a broken wire to that coil, unless
you swapped a bad coil into the same position ..... somehow
Bummer, can you get a distributor on that engine at all ?
Offline zaggy
  • 1134
« Reply #4 on: July 05, 2006, 11:05:28 PM »
Hey Mike
Went through a similar problem recently on a 16v/sohc/1300 that was equipped with direct fire. I believe the systems are similar.
Chased everything only to find out the plug on the computer hand pulled back a smidge (1/16th of an inch) caused a dead #2 cylinder.
Pushed it back in...everything works fine, now it has a tie strap keeping it in.
Worth a shot...
Zag
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #5 on: July 06, 2006, 12:13:44 AM »
Im pretty sure its the computer. I followed the wiring harness and the ecm controls the spark. I pulled the ECM and sent it with my sister to try it in her freinds vitara. It is also a 99 2.0 auto. It also missed on the #2 cyl so Im pretty sure that that was it. Im going to order one tomorow.
Mike
