Electrical issues - battery arc
  • 1601 Views
Offline Zuki One
  • 441
    • ZUKI - PICS
« on: July 04, 2006, 10:23:26 AM »
So i was just movin the zuki around the yard! And i forgot the battery was unstrapped, then i saw this stump taunting me so i put it in 2lo and ran it over it was all good until i came down the backside the engine died. So up comes the hood and i see the battery laying on the intake arced and dead so i put the charger on the battery overnight, so now the battery is holding a charge but im getting that stupid clicking you know like the classic starter problem!
why wont this start  :'(
P.S. im back and its been awhile!   8)
"Sooo What shop built your rig?"hahahahhahahah    www.cardomain.com/memberpage/607888/1
Offline reb
  • 195
  • Victim of CRS--Can't Remember Anything.
Re: Electrical issues - battery arc
« Reply #1 on: July 04, 2006, 11:40:26 AM »
I would check all the normal things:  Are the terminals clean?; Is the ground connection good?; Are the cables ok?; Is the acid level ok?; etc.  The battery might have a problem.    The battery just went south on my tractor yesterday.  I determined that by monitoring the voltage on the terminals while the CFO tried to crank it.  The voltage dropped to almost zero when she turned the switch.
« Reply #2 on: July 04, 2006, 11:40:51 AM »
A big discharge might have bent the plates. Have you checked the electrolyte level? Also check that you haven't damaged the cables.
Offline Zuki One
  • 441
    • ZUKI - PICS
« Reply #3 on: July 04, 2006, 12:07:27 PM »
uhmm my battery drops to 12.4 dcv and all my cables are good ! im jus gettin that f|removethispart|@ckn clickn noise i haven,t checked the fluid and itsa 6mnth old die hard? i will check with a deep cycle here in a few
