Towing with a Samurai....
  • 10 Replies
  • 6354 Views
Offline supermanwv
  • 38
« on: July 05, 2006, 05:51:45 AM »
Can anyone tell me what the towing capacity is for a Samurai?  I have a 5'x10' trailer I was wondering if a Samurai could pull it.
Thanks for any info you can give...
Clark
Offline zukzilla1662
  • 90
Re: Towing with a Samurai....
« Reply #1 on: July 05, 2006, 07:04:15 AM »
does your samurai have a lift and bigger tires if it does than probably not
Offline noff21
  • 32
  • Find them... Please don't grind them.
« Reply #2 on: July 05, 2006, 07:06:47 AM »
If the trailer is empty then you might get up to 60MPH on the highway......
90 Samurai 4" lift finally installed.  Now it's time for some good tires.
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
« Reply #3 on: July 05, 2006, 08:42:16 AM »
I towed my 3000lb tow dolly with mine, it was lifted and 31's.  did about 55-60 mph down the road.
Offline bbagwell
  • 278
« Reply #4 on: July 05, 2006, 11:37:16 AM »
It could probably pull it empty.
2002 Suzuki Grand Vitara
1983 Toyota PU
Offline jzap
  • 515
  • How difficult can it be?
« Reply #5 on: July 05, 2006, 08:27:26 PM »
Not sure about the Sami.  Probably the same 1000 lbs that seems to be the default figure that they give for about everything smaller than a Suburban :) :) ???
The Tracker has a 1000 lb tow rating.  The Tracker pulls my 780 lb popup camper (loaded down with gear, probably pushing the 1K mark) pretty well.  No problems with sway, just a bit slow off the line.  I used to own a Sami, but never tried to tow with it.  I wouldn't hesitate to try to pull the camper with a Sami, but with the shorter wheelbase, higher CG, narrower track and smaller engine, I don't think it would do as well or be as stable.
« Last Edit: July 05, 2006, 08:29:15 PM by jzap »
Jim Z.
66 Apache camper
Offline Vagabond
  • 95
« Reply #6 on: July 05, 2006, 09:57:24 PM »
According to the Samurai users manual, the towing capacity is 1,000 lbs.
[/url]
Offline supermanwv
  • 38
« Reply #7 on: July 06, 2006, 04:40:27 AM »
Thanks for the info everyone.  I appreciate it.
Clark
« Reply #8 on: July 06, 2006, 06:04:52 AM »
The towing capacities seem to be a regional thing. Here in the UK they are much higher for the Track/Kick (2543lbs braked/1653lbs unbraked). Those figures may be based on what the UK legislation allows -1653lbs/750kg is the legal max for an unbraked trailer. I've towed a car trailer with an SJ on it and it managed OK, lots of use of the lower gears on hills though.
I don't have all the figures for my 413 pick up but its max. towing capacity is stated at 2420lbs. Its an lwb so therefore should be a bit more stable, but I reckon the 1.3 would really struggle to pull anything like that figure.
That tow dolly, was that 3000lbs loaded or a tow dolly with a 3000lbs max. capability?
Even with a braked trailer I found that the Vits braking system was working harder than I'd like.
Offline john1974
  • 617
    • Zuknation
« Reply #9 on: July 06, 2006, 08:37:59 AM »
Tow dolly loaded, I meant to say.
« Reply #10 on: July 06, 2006, 09:34:27 AM »
Well I just bought a NOS towbar for the pick up so I'll find out what it tows like before too long. Its going to get a 1.6 in the next few weeks though.
