engine clatter
  • 1842 Views
Offline puddlejumper
  • 40
  • Hummer escape pod.
engine clatter
« on: February 05, 2005, 01:06:56 AM »
Hi everyone!
The puddlejumper is acting up again.
I finally took my truck out 4 wheeling yesterday, and durning that time I was reving the motor much higher than I have since I bought this thing, in the 5-5.5 thousand range.  The engine seemed just fine and put out PLENTY of power (I will now keep this thing till the frame rusts in half.
Anyhow, on the way home, I noticed the engine making a clattering sound when I apply power.  It actually sounds like excessive valve lash.  It only makes the sound when accelerating, and is worst when there is load on the engine, ie: driving.  It barely does it if I just rev the motor from a standstill.  The truck now has 96000 miles on it and has never had the lash adjusted as far as I can tell.  But will reving the motor hard for awhile cause this to become noticeable?
Thanks
My other car is a Freightliner.
Re: engine clatter
« Reply #1 on: February 05, 2005, 01:38:57 PM »
That's piston slap, common sound,
worse when cold, I bet you blew out
some carbon buildup and can hear the
loose pistons, not to worry
Offline zookaholic
  • 387
  • "asphalt was created so yuppies could go 4 wheelin
Re: engine clatter
« Reply #2 on: February 05, 2005, 02:04:57 PM »
its a suzuki, it will run upside down! i know!!!!!! ;D
1987 Samurai, neon green, 1.3 stocker, 6.4:1 trail tough tranfercase, spoa, warn 8000, 34" swampers
1988 samurai (project, on blocks)
