CB Antenna
  • 22 Replies
  • 5749 Views
Offline fullsink18
  • 250
  • Wheel Me!
CB Antenna
« on: July 06, 2006, 12:31:35 PM »
Got a 40 channel CB for free brand new.  But it needs an antenna.  Any recomendations on the type or brand of antenna?
94 2dr kick 8v
-     Full set of Calmini's skid plates, calmini header and full exhaust, k&n filter, sky idler arm, calmini idler arm brace and truss with stabalizer, lock-rite rear locker, Calmini 3"  BL, 2" Digger Spacers, Shrockworks bumper, chicago electric 8,000lb winch, 31" Grabber AT2, 15x7 2
Offline Maroon Monsoon
  • 876
Re: CB Antenna
« Reply #1 on: July 06, 2006, 12:35:29 PM »
get one that's really flexible with an adjustable end so you can get optimal range and durability
don't think brand really matters
Offline fullsink18
  • 250
  • Wheel Me!
Re: CB Antenna
« Reply #2 on: July 06, 2006, 12:37:04 PM »
94 2dr kick 8v
Re: CB Antenna
« Reply #3 on: July 06, 2006, 12:37:49 PM »
Any thoughts on a magnetic / clip-on? We have theft issues here, so I want to pull mine inside when not in use.
Offline fullsink18
  • 250
  • Wheel Me!
Re: CB Antenna
« Reply #4 on: July 06, 2006, 12:39:19 PM »
I was also considering a magnetic one.  Where do you run the wires out of though.
94 2dr kick 8v
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
Re: CB Antenna
« Reply #5 on: July 06, 2006, 12:40:46 PM »
4 foot firestick, very nice ant...
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: CB Antenna
« Reply #6 on: July 06, 2006, 01:59:20 PM »
I have yet to see a through-glass style one that was worth anything. They're junk.
Don't expect a magnet mount style to stay with you in the woods. Plus if you have a soft top, where would you stick it? The hood?
Best bet would be a hard-mount style with a spring base, flexible whip and tunable tip...
If you're worried about theft, just unscrew the mast/spring from the base and stick it inside when not in use... Just be sure to put it back before trying to use the CB... transmitting without an antenna hooked up can damage some cbs...
Offline fullsink18
  • 250
  • Wheel Me!
Re: CB Antenna
« Reply #7 on: July 06, 2006, 02:06:37 PM »
Know of any sites I can get one for a fair price.
94 2dr kick 8v
Offline Digger
  • 1991
Re: CB Antenna
« Reply #8 on: July 06, 2006, 02:08:03 PM »
Truck stops and travel centers are actually pretty good places to find all kinds of CB equiptment.
Offline Quaddawg
  • 1622
    • My Ebay Store
Re: CB Antenna
« Reply #9 on: July 06, 2006, 03:13:59 PM »
Truck stops,  Ebay.
Firesticks RULE..
get a spring!!!!!  I broke two good antennas before I broke down and  bought a spring.
  • 876
Re: CB Antenna
« Reply #10 on: July 06, 2006, 08:53:31 PM »
if you get a flexible antenna you don't need a spring, it's firesticks and other stiff ones like that where you need a spring
Offline JayN
  • 220
Re: CB Antenna
« Reply #11 on: July 06, 2006, 09:00:03 PM »
i agree, i have a super flexy one form a local truck shop. mine is tuned at almost as perfect as they come as well. ;D
96 sport, safari rack, lift
1970 gmc truck
1950 dodge truck
1974 corolla
Offline SnoFalls
  • 1358
Re: CB Antenna
« Reply #12 on: July 07, 2006, 12:04:16 PM »
I've put one of these http://www.firestik.com/Catalog/e36.htm through it's paces ...
I get a good SWR outta the box, and have BASHED it into low branches, etc and not been a problem. (there's also a 48" version).
I mount mine up center on roof or targa ...
Offline fullsink18
  • 250
  • Wheel Me!
Re: CB Antenna
« Reply #13 on: July 11, 2006, 07:21:23 AM »
Trying to get some off the loose ends tied up before Gon Zukin'.
I finally purchased an antenna: Firestik
High performance CB antenna kits complete with a 3 foot antenna, and a 3-way mounting bracket that will allow you to mount the antenna on a vertical or horizontal mirror arm or rail as well as directly to any flat vertical surface. The kits also includes an 18 foot Fire-Flex cable made from top grade RG-58A/U coaxial cable complete with two screw-on PL-259 connections. And, as a bonus for purchasing a complete kit, we throw in a FREE stainless steel spring and a FREE microphone hanger.
Rated |removethispart|@ 400 watts
This morning I bought a antenna, fire extinguisher, and ARB snatch strap.
Bye Bye Paycheck :-\
94 2dr kick 8v
Re: CB Antenna
« Reply #14 on: July 11, 2006, 11:48:51 AM »
Nice, now you just need to mount it.  :)
I tried putting mine on the side of the SJ, but I broke off the first cheapo radio shack antenna I had on there.  So I moved it to the back corner instead, right next to the tailgate.  I haven't had a problem with it there since, but the range is a bit more limited then with a higher mounting point.
