will this help?
  • 2163 Views
Offline zukzilla1662
  • 90
will this help?
« on: July 06, 2006, 06:57:14 PM »
i have a 1.3 that is stock and i plan on adding
- empi carb
- try y header
- 2'' exhaust
- 5:38 axel gears
will i noticea difference
« Last Edit: July 06, 2006, 06:58:54 PM by zukzilla1662 »
Re: will this help?
« Reply #1 on: July 07, 2006, 03:42:45 PM »
A solid difference.  But what size tires are you running?  If you just a little underpowered, I would do the engine mods first, then check to see if you still need the gears.
Re: will this help?
« Reply #2 on: July 07, 2006, 03:52:44 PM »
I'd do the gears first, but that's me :) I like CRAWLING over rocks.  You will notice a big difference with mods + Gearing. Gearing will put your engine back into it's intended power range during normal driving.
Re: will this help?
« Reply #3 on: July 08, 2006, 03:03:13 PM »
True, but if you want to crawl, get a 4:1 first.  :)
If he is only putting 29" tires on, he may not need to gear that low.  My brother was lucky and I just threw my old 410 transfer case under his when he went to the 28.5" tires.  ;D
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
Re: will this help?
« Reply #4 on: July 08, 2006, 03:34:46 PM »
if your only running 31's and dont plan on going up then 5:38's are going to be two steep, 4.62's are perfect for 31's. and then if u wanted u could do T-case gears for added crawl ratio,
the rest will make a difference, I run 2 inch exhaust, weber carb, KN airfilter on stock 1.3, running 31x10.5's all stock gearing and I can run 70mph easy.  I do have 4.62's to go in tho...
all the stuff your running will make a difference, but like I said those gears are too steep for 31's and if u plan on running on road, if its just a trail rig, then u fine.
John
  • 90
Re: will this help?
« Reply #5 on: July 08, 2006, 08:41:47 PM »
i have 32 and want to run 34's
