A few newbie questions?
  • 3334 Views
Offline Stinger
  • 15
« on: July 06, 2006, 08:46:33 PM »
Hello all. I am new to the forum and to the suzuki 4x4's.
I have the chance to pick up a 1988 Suzuki Samurai 1.3l 4x4. The truck has 98k miles on it. Has a brand new Bestop. Body is in pretty fair condition. A few holes in the rear corners and some rust on the bumpers. Was told the engine has a knock. From what I understand the top end sounds clean but has a knocking noise coming from the bottom of the engine. If I get the truck and drop the oil pan, what am I looking for in order to tell if it spun a bearing or worse? The owner only wants $500 for the truck.
If it ends up needing a crank, is there a place to get a new one for cheap. I am trying to build a budget offroad. I am planning on getting a Spidertraxx lift and getting diamond plate to cover the rocker panels and the rear corners.
Any suggestions from Zuk owners would be greatly appreciated.  THanks
Offline SnoFalls
  • 1358
Re: A few newbie questions?
« Reply #1 on: July 07, 2006, 12:06:27 PM »
buy it, and find a donor 1.6l motor to swap in.
diamond plate? I thought you said budget?
Offline takai
  • 907
« Reply #2 on: July 07, 2006, 12:14:44 PM »
I have to agree with the 1.6 swap, best modification I have done to date.
Shop around before you get your heart set on the SpiderTrax Lift. If you are on a budget try looking at some of the set-ups from Trail Tough or Hawk.
'Cause, I am to misbehave.
« Reply #3 on: July 07, 2006, 03:29:56 PM »
If you want budget rocker panels, a couple pieces of good sized angle iron can be made to bolt right onto the rocker panels.  I haven't had mine bend up yet.  :D
« Reply #4 on: July 07, 2006, 03:46:14 PM »
I've been looking into this angle iron thing... have any pics of how you attatched them?
And - if the lower end of the engine is dead - just swap out a bottom end 1.6L. Would be the same cost as repairing the 1.3L, and you'll have WAY WAY WAY better power - and acutally better gas mileage. Just so you know - You'll need to get a mild lift, or modify the 1.3L oil pain to work with the 1.6L, as the 1.6L is "taller" than the 1.3
Offline SnoFalls
  • 1358
« Reply #5 on: July 07, 2006, 03:59:24 PM »
yea, but you helped mine get trashed  ;D (it's all good) ...
I think your trac needs to "follow me" some day ...  ;D
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
« Reply #6 on: July 08, 2006, 01:00:11 AM »
I have to say buy it for $500 even if you part it out you can make back twice that in parts.
I would look at www.sky-manufaturing.com and the budget lift $380 they sell with the over the top steering correction I've been running it for a year with out any problems.
if is the only lift I found for under $500 that had the over the top steering fix.
Mean Green Wheeling Machine
« Reply #7 on: July 08, 2006, 07:28:19 PM »
Hey Bash, I finally put that check in the mail.  It only took me a month.  ;D
Anyway, here are some pictures of the mounting for a simple rocker protection.  We used a plate of 1/4" flat for a backing to stop the bolts from pulling through the body and galvanized steel so it wouldn't look bad when we wore through the paint.
For the mounting we drilled the holes in the angle, put it against the body, marked, drilled through, measured, drilled the flat plate, bolted everything in position.  The first two bolts go into the cab, the second two go under the body.  With two people and a floor jack it took a couple of hours to complete.
« Reply #8 on: July 09, 2006, 02:10:05 AM »
How about I will follow you as long as the roads are paved.  ;D
